Operating a jvc tv w/o a remote
Original remote gone. want to get to auto add channels without a remote. Can't figure out how to operate without one.
How to oprate universal philips remote for JVC tv
Posted on Nov 12, 2008
  • 975 Answers
WELL ,try going to the MENU on your TV , some TVs can be done directly without the remote, hope this helps AJ
Posted on May 14, 2008
Emotion tv
You will need three things to get this to start working again.
1. the original remote control that came with your TV.
2. the operating manual that original came with your TV.
3. and the ability to read the operating manual and follow the instructions on setting up the tv channels auto scan.
Oct 29, 2013 | Televison & Video
There is no local channel,cable only international..i lost my manual,
Hello
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?† To AUTO TUNER SETUP
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?† To CHANNEL SUMMARY
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
AUTO TUNER SETUP
CABLE
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
My neighbor has acquired a jvc tv/vcr combo w/ original remote. when she wanted to program it for cable it only seemed to do ch. 33 - 79 channel 2-32 did not show up. We also could not figure out after...
Your cable company has probably started distributing 2-32 as digital channels. The JVC only has analog NTSC capability. You can acquire an inexpensive digital tuner for around $40 to solve the problem.
Oct 27, 2010 | JVC TV-20F244 20 in. TV/VCR Combo
I purchased a URC-7940. My NEC TV is working with code 0869. Original remote contreol was a RC-1077E. No provision made on TV to operate colour and contrast; could only be done from original remote...
So the remote that came with the TV was the RC-1077E?The only way you can get into the options you mentioned now is that you are going to have to use the buttons on the TV itself.They can be on any 1 of the four sides.I have seen them everywhere.We have to do the same with our JVC.They are pretty much the same button options as the original remote.Menu,volume,channel etc. Good luck! Greg
Aug 11, 2010 | One For All Stealth TV Remote Control
My JVC model AV27330 has a constant blue screen. I can go thru Video 1, video 2, video 3 and then says chn 04 but should be 03 - when I push channel button down channel 105 shows or the other way channel...
You need to use the original remote and call up the customer menu; select auto program or channel program and see if reprogramming will help.
If no JVC remote you have only one other choice----connect a DVD or VCR to one of the video inputs and see if the set functions that way.
SD TECH
Aug 09, 2010 | JVC AV-27530 27" TV
Manual menu button not working after adding channel-no RCA remote only disconnected DirecTV remote
Normally if you unplug the tv for 10 min everything resets, if not look behind for a reset button
May 13, 2009 | RCA F25216BC 25" TV
Tv will not recognize channels to save, goes to black screen
If you want to get the original remote for this model (AV-30W776), you can find it at this JVC parts ditrubutor:
JVC AV-30W776 Replacement Part Remote Control
Jan 09, 2009 | JVC AV-30W776 30" TV
Remove CC Black Box without original remote?
Hello, I was the one who assisted you in Live Chat, Just wanted to remind you to rate the chat session, Thanks. Have a great day!
Nov 25, 2008 | JVC AV-32260 32" TV
No jvc remote, can't access
Nothing can fully substitute for the original remote. However, I'm not too clear on why you're not able to do an auto-programming.
If you would like to replace the original remote and don't want to spend $50 or more dollars, consider this alternative:
http://www.miracleremote.com/
We have just about all of these in the shop and they really do access ALL the functions of the original.
Bill
Nov 20, 2007 | JVC AV-27230 27" TV
Television not getting all of the channels
I hate to tell you this but you cannot add channels without an original replacement remote, and that costs about 40 bucks here http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=TC2556D&brand_pn=EMERSON_TC2556D&mode=large&uid=11743431409220 This remote if you notice has an add, delete,and the auto buttons. A universal will not have these functions on it. Good Luck.
Mar 19, 2007 | Emerson TC2556D TV
Televison & Video Logo
289 people viewed this question
Top Televison & Video Experts
