Question about Gestetner Copier
Gestetner 3225 error code SC544 - functional problem
  • 1,110 Answers
SC544 indicates low fuser temperature during the warm up process. This means you have a problem with the fusing unit heating up. The fusing unit is located right where the paper exits the machine. Most common failure on these Ricoh's (Your Gestetner 3225 is made by Ricoh model aficio 250) is the fuser thermistor. This is a small electronic part that measures the temperature of the fusing roller. When they go bad they do not "see" the heat and therefor the code pops up. You are going to need to have a tech look at this for you as you will need to determine for sure which part is bad then you have to go into the service mode to reset this SC code before the machine will run.
Good Luck and Thank You for using Fixya.
Posted on Sep 07, 2010
Clear error code on SC544
What is it on?? If a printer unplug it & wait 1 min & plug back in. If still does it go to the Manufactures web page & look in Frequent answers.
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
Dec 14, 2014 | Office Equipment & Supplies
Savin 8045 sc544
error 544 is associated with the fuser, call aechnician to change the thermisters and thermofuse of the fuser and the problem is solved
goodluck
Feb 05, 2014 | Gestetner Office Equipment & Supplies
My canon ir 3225 is giving me e000805-0003,where is the problem?
A E000805-003 is a error code for a fan that is not working correctly
Dec 19, 2012 | Canon imageRUNNER 3225 Black and White...
Error sc 321 @ Gas. 3225 photocopier
What is the brand? If it is a Ricoh/Gestetner product, the SC321 is a bad Laser Diode unit. Quite expensive but also obsolete.
Mar 09, 2011 | Office Equipment & Supplies
Error sc:544
Hi
SC544 error means Fuser Overheat Error 1 (Hardware). This has happened due to Fuser Low Temperature which occurs due to Abnormal Hot Roller Fusing Lamp Lower Limit Temperature Detected. Try turning off & unplugging the copier for 10-20 minutes to check if error code resets. If it doesn
Oct 09, 2010 | Gestetner DSm615 Digital Imaging System
Service code sc544
It is a fuser overheat error....really has to be checked by a technician...
note that any Ricoh tech can also do it as it is a Ricoh machine
Nov 06, 2009 | Gestetner DSc224 Copier
Gestetner 3225
SC401: Transfer roller leak error 1
SC402: Transfer roller leak error 2
-Definition- [B]
A transfer roller current leak signal is detected.
The current feedback signal for the transfer roller is not detected.
- Possible causes -
· High voltage supply board defective
· Poor connection of the PCU
· Transfer/separation unit set incorrectly
Jul 23, 2008 | Gestetner DSm618 All-In-One Printer
Error code SC 544
Relates to fuser unit. Needs to be reset from service mode.
Mar 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Gestetner 3225
Ax060267,This is the part number of the polygon mirror motor , it is worn out , your machine propably makes a high reving noise aswell when it starts to print , you can go to your nearest rico or gestetner outlet and get a new motor , it sits right in the middle of the machine , sometomes it helps to remove the motor and oil it with a very thin oil , but in mostcases it is beond repair .
Oct 24, 2007 | Gestetner DSm618 All-In-One Printer
816 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
