Question about LG Goldstar LD65EL Dehumidifier
The motor runs hot but produces no water - LG Goldstar LD65EL Dehumidifier
    Master:
    Sergeant:
  • 449 Answers
Check the condensor unit
Posted on Sep 08, 2010
I have had the machine on for 5 days on high and have extracted less then a 1/4 inch of water. The back side of the machine is hot and blowing hot air - the motor runs but does not extract water Is it...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 31, 2011 | Whirlpool Dehumidifiers
Dehumidifier makes the room too hot where it is running. does very good removing water need too empty 50 pt every 24-30 hrs.
The dehumidifier does not heat or cool, but the compressor running will produce some heat and it can make a room hotter...
heatman101
Aug 29, 2010 | GE AHG40LJ Dehumidifier
I have a EBAC 2800E. The problem is it does not dehumidify. When the equipment is switched on the motor runs and it gets warm but it does not produce any water in the tank. Does this indicate that it...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Aug 23, 2010 | Dehumidifiers
It is not producing water, it runs but no water is collecting in pan.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue.
This situation will have to be addressed by a qualified technician.
Take care.
Aug 19, 2010 | Whirlpool AD25BBK Dehumidifier
Motor runs fan works does not produce water and black tank in back (compressor?) is very hot
Make sure that the coils of the evaporator are clean, and that the unit is getting proper airflow across the evaporator and condenser coils. Hope this helps
Sep 25, 2009 | Fedders A7DH45B2A Dehumidifier
Dehumidifier runs but doesn't produce water
Your dehumidifier has a circulating fan that draws the room air over the coils. If there's no air movement out the front or back of the unit, the fan motor may be burned out or stuck, or the fan blade may be broken. If so, you need to replace the fan motor or the fan blade.
Sep 04, 2009 | Kenmore 5230 Dehumidifier
Top of dehumidifier is very hot to the touch, filter is clean don't know what to do, afraid to put it on in case of fire.
Are you running it in high ambient temperatures?
Can you see any condensate(water) on the coil?
It may be that it is running above it's temperature range. A dehumidifier has two coils(radiators if you like). One gets cold, the other gets hot. The first one renoves the moisture from the air, this is the evaporator and is cold. The heat taken from the air is absorbed into the refrigerant and is given back to the air when it passes through th other coil, the condensor which is hot. The refrigeration circuit itself produces heat. This heat plus the heat absorbed from the air has to be got rid of. If the ambient temperature is high, the condensor will have trouble getting rid of the heat from the circuit. This can cause the case to feel hot to the touch. Assuming you don't have a refrigeration leak, it may not be worth running the unit if it is not removing moisture from the air. Is any water being dropped into the bucket? If it isn't, all you are doing is wasting electricity.
Aug 15, 2009 | Midea MDC-45AE Dehumidifier
Not collecting water
If everything is running and no water is being produced the system may have lost its refrigerant. There are two motors in dehumidifiers. One is the fan and the other is the compressor. Make sure they are both running.
Jun 18, 2008 | Goldstar DH304 Dehumidifier
Fan does not come on
I've seen abunch of these. The fan motor has a fuse wound into the windings. It cannot be replaced you need a new fan motor. The motors seem to run hot normally, leading to a short lifespan.
 I suggest buying a better brand unit.
Oct 23, 2007 | Comfort-Aire BHD-651 Dehumidifier
Dehumidifiers Logo
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
