Question about HP Deskjet F2180 All-In-One InkJet Printer
Can you help me to fit my new hp deskjet ink cartridge (new at this)
  • 6,831 Answers
Hello
OK, at the link below you will be able to get step by step instructions on how to install new cartridges.
Click HERE to navigate to the page.
Please be so kind to rate this solution.
Kind regards
Andrea
Posted on Sep 07, 2010
Can a hp 56 ink cartridge be substutited for a 60 hp black ink cartridge
No, it cannot. I tested it on an HP DeskJet F2430. The HP56
will not fit in the HP60 carrier.
Dec 04, 2012 | HP DeskJet F4280 All In One Printer InkJet
Will HP 60 ink cartridge work with HP Deskjet 2460? Tnx.
This is all HP recommends for the HP Deskjet 2460, so I wouldn't suggest buying anything else. First of all it might not fit and second, even if it fits, other issues may come with using those. If you can't see the list here it is:
HP 21 Black HP 21 Black Twinpack HP 21/22 Black/Color Combo HP 21/22 Quad Pack HP 22 Tri-color Twinpack HP 22 Tricolor HP 58 Photo
Jun 23, 2011 | Office Equipment & Supplies
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    Light blinking says ink cartridge problem. fitted new cartridges still showing problem
    kindly make sure the ink cartridge are fitted nicely on the ink cartridge holder
    Nov 27, 2009 | HP DeskJet 3745 Printer
    F4235 cartridge will not fit in slot
    Hello.
    Be certain that you are using the HP 60 (CD947FN) Black/Tricolor Ink Cartridge.
    If you have the correct cartridge, it should fit and just snap into place.
    Hope this helps.
    Nov 13, 2009 | HP DeskJet 920c InkJet Printer
    Which HP printers use #56 & 57 cartridges ?
    Fits Models: Deskjet 450cbi ... 1350 PSC ( 57 56 HP C6657AN Ph C6656AN 57 56 HP C6657AN Ph C6656AN 57 56 HP ....
    Hope this helps. Bud
    Jan 09, 2009 | HP DeskJet 5150 InkJet Printer
    HP Deskjet 950C - trouble loading ink cartridges
    1st thing would be to remove the cartridge & check for any damage to the copper contacts as these are what tell the printer that a new cart has been installed. Next make sure you removed the tape covering the nozzles (I've done this before & boy do you feel silly).
    If this all looks OK then pull the power out while the cart is still not fitted (this will fully reset the printer).
    Once it comes back up, try fitting the cart again also checking that the contacts in the cartridge holder are not damaged/dirty.
    This should sort the problem
    Cheers
    Shaun
    Jan 26, 2007 | HP DeskJet 950c / ScanJet 5370C InkJet...
    HP Deskjet F2180 All-In-One InkJet Printer Logo
    55 people viewed this question
    Seeker5211
    Seeker5211
