Question about Singer 3116 Simple
The bobbin holder pops out when I begin sewing. The thread birdnests and fabric gets stuck. I checked bobbin case holder and removed and replaced the 2 metal parts. i also adjusted tension bot hways. no luck. Please help
    Genius:
  • 1,788 Answers
Call Singer customer service at 1-800-4singer and they can guide you.
Posted on Sep 13, 2010
Where to apply oil to shuttle on White model 2037. I thoroughly cleaned all parts of the machine, rewound bobbins, made sure presser foot was up and rethreaded machine, still getting birdnesting under
If the birdnesting is on the bottom of fabric it is the top tension. If the birdnesting is in the bobbin area I would check the bobbin tension. When adjusting the bobbin tension make sure you are turning the screw in very tiny increments.
Check to make sure the machine is threaded properly and then check again. It is often times something simple.
Jul 07, 2017 | Sewing Machines
Fixing the problem of birdnesting
Birdnesting is a common but very frustrating problem that can be resolved easily once you know where the problem originates. Remember, if the birdnesting occurs on the underside of the fabric, the problem originates with the upper thread. If it shows on the top of the fabric, the problem is the bobbin.
Very often, the machine is not threaded correctly. Remove all the thread from the machine. Check there are no loose threads or lint stuck anywhere in the machine. Oil as instructed in the manual.
Install a brand new needle! The needle should be suitable for the thread and fabric you are using. All About Needles
ALWAYS RAISE the presser foot and rethread the upper thread. Verify the path is correct.
Check that the bobbin is installed and threaded properly.
Pull the bobbin thread to the top of the fabric.
How and Why to Bring up the Bobbin Thread
Set the upper tension to the midway point.
While holding both thread tails lightly in your left hand, begin sewing slowly.
sewing machine birdnesting Google Search
Oct 27, 2016 | Sewing Machines
I have a singer prelude sewing machine - the thread started binding from the bobbin up - there were about 50 threads pierced through my test patch.
what you describe is thread bunching and is typical of the needle thread tension being too loose
adjust that right up, run a test sew and go from there
Aug 07, 2016 | Singer Sewing Machines
I have a elna lotus sp, it keeps bunching up underneith, ive had it working. I've changed the needle , it's starts sewing then stops due to it getting tangled ,
try another needle-- one for the fabric being sewed
make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
make sure the bobbin is inserted into the bobbin case correctly
make sure the bobbin is turned the correct way in the bobbin case
Mar 09, 2016 | Elna Sewing Machines
Cotton is loose/looping under material?
Sounds like bird nesting.
The #1 thing is to install a brand new needle (old, worn, nicked, or bent needles can create a lot of havoc).
Remove all the thread from the machine. RAISE the presser foot and rethread from the beginning verifying that it is threaded correctly. Make sure the bobbin is loaded and threaded in the bobbin case properly.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Why Do Get Bunched Up Thread Under My Fabric
8 Tips to Fix Birdnesting in Embroidery
Jan 28, 2016 | Sewing Machines
Have a Singer 11910000A and the bobber thread bunches up and makes a mess in the feet when sewing
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
Sewing Machine Thread Bunching Up Here Why
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
Birds nest under the fabric big loops of thread top side looks good...
http://www.marthastewart.com/1085057/common-sewing-machine-repair-tips
and here's another Hint that may be helpful:
https://www.youtube.com/watch?v=KDERq4I7l-Q
Dec 29, 2015 | Singer Sewing Machines
My bobbin thread continues to bunch up on the back of the fabric.. How can I fix this?
3 Common Sewing Machine Problems and How to Fix Them
Dec 29, 2015 | Sewing Machines
The upper thread keeps getting caught under the bobbin casing when sewing. The machine will stich, but when I pull it out there 3 threads pulling out instead of the 2 there should be. I have read the...
Other than your machine being out of time and needing service, following are suggestions to try:
Be sure to use the correct type of needle for the thread and fabric you are sewing, ie sharp, top-stitch, embroidery, universal, or microtex for woven fabrics and ball-point needle for fine knits.
AVOID old or bargain bin thread.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Check that the bobbin is turning the correct direction in the bobbin case and the bobbin case is properly threaded.
Set the top tension to the midway point.
Re-test your machine and tweak the top tension so the top and bobbin threads meet in the middle of the fabric.
If the thread continues to hang up, take your machine for service and adjustment.
Jul 27, 2017 | Brother CS-6000
Tangled bobbin thread
Okay. I had this problem too. try taking the bobbin casing out. I had a bit of thread lintg caught in a remote area of the under-plate area. Blow it out with canned air and oil your machine. That should help. It fixed mine.
Jan 16, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer 3116 Simple Logo
147 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
