Question about Cameras
My camera is switched on and the zoom goes out and the in again and it says Zoom Error. I can preview my photos but I cannot take pictures. I fixed it before but I forget how.
  • cats_r_cu948 Sep 07, 2010
    I'm sorry but how do i format it?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 146 Answers
Remove card, format it and then try.
Posted on Sep 07, 2010
I hit something on my camera that each time I take a picture, the preview is a tiny picture in the upper left screen and there are yellow outlines around areas of the picture and in the lower right corner,...
when you are in the playback mode, you can use the zoom function (as you use it when you take a picture), this will zoom into the image you took.
the yellow frame show you where you are in the full image.
Oct 18, 2010 | Canon PowerShot SD1000 Digital Camera
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
Can't take pictures when using zoom.
this unit need factory repair I hope you have a warranty I'm very sorry I would try calling the manufacture and explaining this to them. Good luck
Sep 16, 2009 | Cameras
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Macro in sony W170 digital camera
The resolution of the photo you take determines how grain shows up as you zoom into the Photo, So taking a 10 megapixel photo on optical zoom or no zoom will give you a sharper picture than when you use both the optical and digital zoom to grab your picture. The digital zoom uses the centre of your CCD picture imager rather than the whole CCD so with less elements to your picture when you take it gives you blockiness sooner when you zoom in on the image. I am guessing your friend has digital Zoom turned off in settings to prevent the Graining showing upon magnification. Good light and a steady camera will give you the best results.
Dec 05, 2017 | Sony Cyber-shot DSC-W170 Digital Camera
Zoom error
reset camera but it would appear that the lens is not functioning properly and would need repair
Sep 06, 2008 | Olympus SP-550 UZ Digital Camera
Lens error
This can work with CoolPix S10
1) Remove battery.
2) Replace Battery (Insure it is fully charged)
3) Press the Shooting/Preview button and keep pressing it while you press the power on button. This tells the camera to go into PREVIEW MODE without checking the lens. See if you can preview a few photos and that it works in preview - If it does NOT I cannot help you here.
4) If the Camera Works in Preview mode then press the Shooting/Preview button to put it back into "Take Photo Mode".
5) There can be a delay but it starts up without the lens error.
6) Make sure the ZOOM IN and OUT works and in most cases if the lens operates then you can take a photo. If the Zoom in and Out does not work you have a jammed lens.
7) If the LENS is Jammed AND it is OUT of warranty you 'might' want to tap the lens barrel against your palm. I have found when you remove the battery you can gently tap the lens into telephoto mode by tapping the back of lens assembly into your palm.
May 28, 2008 | Nikon COOLPIX S10 Digital Camera
Shuts down while using the zoom lever
see this thread :
http://www.fixya.com/support/t225803-canon_powershot_s3_switches_off_when
Mar 21, 2008 | Canon PowerShot S3 IS Digital Camera
Can't see the image in PC
It sounds like the images are corrupted. On many cameras, a camera-only preview is also stored alongside the image file, so the camera can quickly display the preview without having to spend time decoding the image file. When you try to apply the zoom, the camera is actually trying to decode the image, which fails because it is corrupted. This might be due to low battery (unlikely), or bad memory. You might try replacing your memory card.
Feb 15, 2007 | Samsung Digimax S500 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
