Hey,
Once done this should solve your problem. Anyways omnia lite has a peculiar problem with the corner parts. Incase if thats what you are referring than nothing can be done. For everything else you may do the screen alignment from settings--general settings - align screen.
Regards,
Ritesh
same thing happen's to mine, and i'v only had mine for two months :O aha, although i believe it's 'cause i got the screen wet, i mean it's happened before but, usually worked but, this time i think that the water dissolved into the phone making the touch screen not work, mine's still not fixed but, trying taking the phone apart and re-building it. That might help.
Kayleigh xx
The issue can be with the flex of your phone that connects to the touch screen. The connection might be loose thereby disabling the touch screen functionality.
The best solution is to take it to Samsung repair shop and get it repaired by an expert. They are well experienced with touch phone firmware malfunction issues.
I think the touch screen is faulty. You not badly treating or overusing the phone does not mean it would not not get spoilt. Remember it an electronic, anything can happen.
You need to take the phone to an expert to change the touch screen for you.
this is a factory fault that cannot be rectified, from time to time the phone will freeze and after a while will function normally as if nothing ever happened. leave the phone alone dont fiddle with it until it resumes normal function
try the calibration in the options. try tapping or if not working, use your buttons. tap or use the button to make the origin at the center of the screen.
double check that both cable/ribbons are connected properly to the motherboard, the small thin ribbon which curls over the top of the motherboard is the one which powers and reads the touch screen so double check this!!
if this is all in fine then im sorry to say your touch screen is broken and will need replacing!
