Question about Shuttle AK38N Motherboard
I have upgaded my system using an ak38 mainboard. I have replace with new parts, the correct memory, power supply, yet the board beeps when I turn it on. Is this possibly a processor problem?
    President:
  • 2,678 Answers
Check the beep code here
Posted on Sep 07, 2010
D845GVAD2 no bios screen no beep no boot
Hello here is the intel homepage:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845GVAD2
Try to renew the power supply, with one you know is working.
I think that`s the problem.
The problem could ofcourse also be the mainboard itselves failing.
There is not much to do about that, other than renew the mainboard or buy a new pc.
Good luck
Apr 08, 2013 | Intel D845GVSR Motherboard
Turns on, then shuts down before anything shows on monitor
Hi m5mm, what kind of Operating system are you using?
Jan 03, 2008 | Gateway GT4022 PC Desktop
On start up fan runs, no beeps, black screen, no response from keyboard & mouse. Unplugged everything for 30 minutes, then tried again, start up began then went to black screen, no keyboard, no m
in your case, there might be some problem with the main board.
usually no beeps will related to the processor error / mainboard error / ram error / PSU error
to check the processor : try to exchange the processor with the same type.
to check the Memory: try use rubber eraser to clean the cooper plate of the memory. then plugged it again.
in case if there is a power supply error, then try to exchange the power supply using other PC PSU.
if all steps above are checked, the problem might be at the mainboard. in that case, replacement will be the best option.
Jan 20, 2012 | Acer Computers & Internet
I changed the power supply on my acer aspire e700 and it beeps continuosly non stop with no picture on screen, the last power supply blew. it had a graphics card when i bought it but it stopped working so...
You may have more problems than just he power supply from when the old power supply went out. The mainboard could be bad.
Make sure it's unplugged from power from the wall, then check that the memory is seated correctly. Check for anything else that may be out of place or not fully connected.
There are also different beep codes for different errors. They've mostly been standardized, but may vary by mainboard as well. Here's a link to common POST beep codes and their meanings:
Computer POST and beep codes
May 19, 2017 | Acer Aspire E700 PC Desktop
My d530 minitower powers off unexpectedly and red lights starts to blink on System's LED//
Hi Kindly let me know how many times the red light blinks
Condition Code Service Actions Processor thermal protection activated. Power LED blinks red twice, once a second, followed by a two second pause.
  1. Make sure the computer air vents are not blocked and that the cooling fan is running.
  2. Open the hood, press the power button, and see if the processor fan spins. If the fan is not spinning, make sure the fan cable is plugged into the cable header on the system board, and that the fan is properly installed and seated.
  3. If the fan is plugged in and seated properly, but is still not spinning, replace the processor fan.
  4. Reseat the processor heatsink and make sure the fan assembly is attached to the heatsink properly.
Processor is not installed. Power LED blinks red three times, once a second, followed by a two second pause.
NOTE: This condition indicates a missing or improperly installed processor, not a defective one.
Make sure there is a processor in the system. Reseat the processor and verify that it is installed properly. Power failure (power supply is overloaded) Power LED blinks red four times, once a second, followed by a two second pause.
  1. Check the voltage selector, located on the rear of the power supply, is set to the correct voltage (the correct setting depends on the region).
  2. Open the hood and make sure the 4-wire power supply cable is fully connected to the power connector on the system board.
  3. Check if a device is causing the problem by removing all attached devices (such as disk drives and expansion cards), then power on the system. If the system enters POST, power off and replace one device at a time, repeating the procedure until the system power failure reoccurs. Replace the device that caused the failure, then replace each of the other devices and confirm that they are functioning properly.
  4. If you cannot isolate the failure to a specific device in the previous step, replace the power supply. **
  5. Replace the system board.*
Pre-video memory error. Power LED blinks red five times, once a second, followed by a two second pause, and five simultaneous beeps are sounded
  1. Reseat the DIMMs in the memory slots on the system board, then power on the system.
  2. Replace the DIMMs one at a time to isolate the faulty module.
  3. Replace 3rd-party memory with HP memory.
  4. Replace the system board.*
Pre-video graphics error. Power LED blinks red six times, once every second, followed by a two second pause, and six simultaneous beeps are sounded. For systems with a graphic card:
  1. Reseat the graphics card and then power on the system.
  2. Replace the graphics card.
  3. Replace the system board.*
For systems with integrated (on-board) graphics, replace the system board. PCA (system board) failure. ROM detected failure prior to video. Power LED blinks red seven times, once a second, followed by a two second pause, and seven simultaneous beeps are sounded. Replace the system board. Invalid ROM based on bad checksum Power LED blinks red eight times, once a second, followed by a two second pause, and eight simultaneous beeps are sounded.
  1. Reflash the ROM using a ROMPaq diskette.
  2. Replace the system board.*
System does not power on. No beeps or blinks since the system is not functioning. Press and hold the power button for less than four seconds. Perform the following steps depending on whether the hard drive LED turns green.
If the hard drive LED turns green, then:
  1. Make sure the voltage selector (which is located on the back of the power supply) is set to the correct voltage for your region.
  2. Remove the expansion cards one at a time until the 3.3V auxiliary light on the system board turns on. If removing a card turns the light on, replace the card and then see if the system works.
If the hard drive LED does not turn green, then:
  1. Make sure the computer is plugged into a functioning AC power outlet.
  2. Open the hood and make sure the power button is securely fastened in the power harness and that the harness is connected properly to the power connector on the system board. In other words, make sure that the power button is making contact with the power circuit.
  3. Make sure the power supply cables are connected properly to the power connectors on the system board.
  4. Check to see if the 3.3V auxiliary light on the system board is not turned on, replace the power supply. **
Dec 29, 2009 | HP Compaq d530 Convertible Minitower PC...
EMachines T2824. Does nothing but light on mainboard coming on...
This is a motherboard problem. You'll need to replace it. Although, it may be cheaper just to buy a new PC (eMachines are never very expensive, or well-made for that matter)
Sep 22, 2009 | Computers & Internet
3 beeps every few minutes
That maybe a memory beep code. Turn it off and remove and re-insert the memory modules on the mainboard.
If this doesnt work, get back to me.
Feb 13, 2009 | Apex Computer Technology Apex Power Supply...
HP P4B-MX beep
HP P4B-MX is Award Bios
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
Jan 19, 2009 | HP (5185-6477) Motherboard
Asrock K7S41/K7S41GX problem
2 x DDR DIMM slots
- Supports DDR400/333 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
3 beeps is usually either video card related, or memory. be sure your memory is UN buffered, and DDR400 or 333 DIMM not DRam.
Remove and re-seat your video card as well.
there should be a troubleshooting guide in your install manual stating the designation of 3 beeps.
Dec 22, 2008 | Asrock P4VM890 Motherboard
No screen, no boot, only the power LED flash orange
In this case you should examine the motherboard and the processor.
verify the Mboard maybe maybe some part oversheat, if non then , Kindly remove the processor, then switch on for a while then shutdown: fix back the procesor and then switch on. still no beeps? try your Processor to other computer system with same socket on mainboard. if the processr work; then your mainboard is damage. u need to replace; if not work. processor is damage and need to replace.
Be sure to test all the pheriperals of your system before you buy a replacement to see if some other parts is no problem.
Like memory, VGA,
If all of the solution is not working its time u to assemble new computer system. i give you all the possible solution, or else tell me the working part i will help you seeking and speicy the replacemnet part.
thank you more power.
Jan 29, 2008 | Acer Aspire 3680 Laptop
Shuttle AK38N Motherboard Logo
62 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
