Question about Canon PowerShot S1 IS Digital Camera
When I look through my lens, the object is totally out of focus no matter what I do. The object looks blurry and color is grayish/brownish. What could be causing this?
    Problem Solver:
  • 5 Answers
You do not say if the pictures you take come out blurred?
I believe this powershot model (depends on the precise model/variant) has an optical adjustment just by the side of the viewfinder (small lever or knob). Try adjusting this to bring your view back into focus.
Check you have not set any special effects on eg soft focus portrait and sepia - probably safer to do a camera reset - see your instruction book.
Good luck
Posted on Sep 07, 2010
Nikon d5100 Blurry photos When I take photos of a party, at night, my photos are very blurry. How can I fix..
Use autofocus if you have a AF lens on it.
Usually you get a kit 18-55 AF lens that has a A/M switch on the side. The switch should be facing the A side so it's set on autofocus. Then you have 9 points on your viewfinder, those are the autofocus points. It should usually be set to center, because you usually want the object in center of your photo to not be blurry.
Remember to press the shutter button halfway and give some time for the autofocus to focus. Then you can press it all the way, you should have your photos nice and clear.
If you happen to have a manual focus lens, you should be watching through the viewfinder and turning the focus ring on the lens and determine if your object is in focus. It's hard at night, but get some practice at home when you have some more light so you get more familiar with the focus.
Dec 26, 2012 | Nikon D5100 Digital Camera
Tip
Explaining Camera Focus
Camera: Focus We've seen that a real image is formed by light moving through a convex lens. The nature of this real image varies depending on how the light travels through the lens. This light path depends on two major factors:
  • The angle of the light beam's entry into the lens
  • The structure of the lens
The angle of light entry changes when you move the object closer or farther away from the lens. You can see this in the diagram below. The light beams from the pencil point enter the lens at a sharper angle when the pencil is closer to the lens and a more obtuse angle when the pencil is farther away. But overall, the lens only bends the light beam to a certain total degree, no matter how it enters. Consequently, light beams that enter at a sharper angle will exit at a more obtuse angle, and vice versa. The total "bending angle" at any particular point on the lens remains constant. camera-diagram3.gif
As you can see, light beams from a closer point converge farther away from the lens than light beams from a point that's farther away. In other words, the real image of a closer object forms farther away from the lens than the real image from a more distant object. You can observe this phenomenon with a simple experiment. Light a candle in the dark, and hold a magnifying glass between it and the wall. You will see an upside down image of the candle on the wall. If the real image of the candle does not fall directly on the wall, it will appear somewhat blurry. The light beams from a particular point don't quite converge at this point. To focus the image, move the magnifying glass closer or farther away from the candle. camera-diagram2.gif
This is what you're doing when you turn the lens of a camera to focus it -- you're moving it closer or farther away from the film surface. As you move the lens, you can line up the focused real image of an object so it falls directly on the film surface. You now know that at any one point, a lens bends light beams to a certain total degree, no matter the light beam's angle of entry. This total "bending angle" is determined by the structure of the lens.
courtesy of HowStuffWorks.com
on Mar 21, 2008 | Canon PowerShot A520 Digital Camera
Camera won't focus on object sindce the picture on the screen is blurry . When you take a picture the picture is blurry Ive checked it on my computer. I've cleaned the lens and still blurry. My...
its likely that she may have hit the macro setting only allowing it to focus up close to objects to turn this off all you have to do is find a button that looks like a flower this could be on the arrow pad or in the menu system but it is called the Macro setting and with it turned off hopefully your pictures will be sharp again
Mar 01, 2011 | Olympus Camedia D-540 Zoom Digital Camera
When i turn on my camera to take a pic it is blurry but if i zoom the lens all the way close to the object it takes a good pic.
Your auto-focus is not working. Inside the camera is a motor that adjusts the lens to focus on an object automatically. It is currently stuck to "close" or near focus. However, it doesn't go far focus. Check the focus functions of you camera - try to use manual focus.
Dec 01, 2010 | General Electric A735 Digital Camera
Using the scope
Well if it was a rifle, I would say far away, or you will get a black eye. But the recoil on a pellet rifle is backwards because the spring jerks the rifle forward, and it messes with rifle scopes, they are made to recoil back, But,,, you have a movable eyepiece in the end where you look through and it will make the cross hairs come into focus for your eyes. some one else might find them blurry. The objective lens, should be in focus no matter what. It doesn't move. and no matter what your vision is, you should be able to see clearly. If not, I'm wondering if it is fogged up. Your eye should be about 3inches, + -, Check it out. Hope this helps.
May 04, 2010 | Crosman 4 x 32 Air Rifle Scope, Black
Does not focus after "far" objects when zoomed to 50mm or more ...
  1. If your images suddenly start looking blurry or distorted, try holding your camera up to the light. If your lens looks dirty, foggy or greasy, try applying lens solution with a lint-free cloth . Move the cloth in a circular motion until the lens dries. Do not apply lens-cleaning solution directly to the lens.
  2. If your images are still blurry, check your shooting mode. If you are shooting closeups, make sure you are using the "closeup" mode. Try to get within 2 feet of your subject before you shoot the picture. images can look more blurry when you are a long way from your subject
hope this helps you please do me rate on this issue
Dec 23, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Blurry, AF not working
Try resetting the camera to it factory condition ..... also open lens and clean the contacts...and then try
Oct 12, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Repair lens PDX10
It sounds like the optics in the lens are no longer calibrated. It needs to be looked at by a professional.
Oct 10, 2008 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
I have a Casio Exilim 7.2 when it is turned on the display is blurry, the photo is blurry and I think the lens in not coming all the way out when it is turned on.The battery is fully charged.
You could be right about the lens...you can try zooming in and out severel times and gently and very discreet try to pull out the lens.Dust and moisture can block the mooving part of the objective so a little shaking and wipeing would help. Also the problem could be in the settings of your camera...you could try resetting to the default settings and probably it will correct the blur caused by the bad focusing(or just try modify the autofocus to manual focus).A third option-in the worse case scenario- would be a scratched(or very dirty) objective that leads to a bad focusing and causing the blurryness.Try wipeing the objective with a soft cloth.Hope it will help you...
Aug 31, 2008 | Cameras
40 DX - blurry pics
The lens is out of focus or the shutter speed is too slow, to determine if this is a defect or failure, mount the camera on a tripod and use the self timer or remote cable (if you have the remote cable) to take exposures while autofocusing on a neutral colored object such as a beige item,
if they're still blurry then manually focus the camera and try again.
If they are still blurry and your Nikon has a diopter focus adjuster (this is typically in the rear next to the viewfinder where you focus your eye), set the diopter to neutral and manually focus again.
If they are still blurry, remove the lens and using a cloth dampened with high percentage or denatured alcohol, clean off contact rings since this is where the lens and the camera body communicate and transfer focus data.
If they are still blurry, then use the same cleaning method for the contact ring of the camera body.
If they are still blurry use a different lens and repeat the first two steps.
If they are still blurry then you may have a smudged and dirty sensor, this is the part which actually registers the image and should be cleaned by a professional.
If you are so brave to, you can use the cameras feature to lock the mirror and expose the sensor, this is typically only done to perform a dust cleaning using light blasts of clean air and using solvents on the sensor is dangerous.
If you choose to do so anyway, use a bright flashlight and look for anything that appears to be smudging, if it isn't apparent then your camera or lenses are likely in bad need of maintenance.
Aug 23, 2008 | Nikon D40x Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
59 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
