Question about Miller DYNASTY 350 TIG WELDER w/TIG TORCH 951074
I have a merkle tig 200 that has ceased to function properly. i used it on Friday with no dramas but cam to use it again yesterday and it refuses to arc up. it will arc at max power to initialize but then continuously expels gas without arcing and it unresponsive to controls. when i run a test on it it cycles through 3 stages then freezes. any solutions or answers to my dilemma are appreciated.
5 Suggested Answers
  • 7 Answers
SOURCE: LINDE HDA 300 TIG WELDER HIGH FREQ. PROBLEMS
The contact should have a gap .008 .
Posted on Mar 21, 2009
keemo68
  • 1263 Answers
SOURCE: miller Syncrowave 250 / no tig arc start
seems that you have a ground issue. make sure the ground clap is on barte metela and secured tight. make sure your tungsten electrod is about 1/8 of an inch form the edge of the cone. you will find that you will get a faster arc this way.
Posted on Apr 19, 2009
  • 87 Answers
SOURCE: Hi, starts to weld fine after a few seconds hi
It sounds like you need to change out your SCR chip on your motherboard; Miller makes one that i have installed on all our 350xl's, I don't have the number on hand but i can get it for you tomorrow.
Posted on Oct 20, 2009
Testimonial: "appreciate the help."
SOURCE: Tig welder wont strike up arc, power to welder ok,
www.millerwelds.com › ProductsTIG -
www.millerwelds.com › Service & Support
Posted on Mar 27, 2010
Wiring diagram cobel tig acdc 200
Go to millerwelders.com and you will find diagrams you need.
May 31, 2014 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
My 200 pontiac sunfire died and lost power on the freeway yesterday and refuses to start again makes a click sound and nothing
Possibly a loose or corroded connection somewhere, or bad alternator, not charging battery and caused system failure. Check for good clean connections at battery and starter. With a volt meter a battery should read 12.4 - 12.6 at rest, if you have a functioning alternator battery should read up to 13.5 to 14.5V .
Jan 12, 2014 | 2000 Pontiac Sunfire
GIANT WSE 200 amp ac dc tig welder
Buy a new circuit board as it will be cheaper in the long run as the solder has damaged vital parts on the board. It will take a lot of frustration in fixing all parts .
Apr 04, 2013 | Welding Tools
Can't set up syncrowave 351 to tig weld aluminum. I can not seem to get the settings right to melt the aluminum. It just leaves a bif spot on the aluminum plate.The plate is about 1/4" thick and...
Set the "arc balance" control between 40-50, also. You need to be up around 200-220 amps too. Make sure you're using 3/32 tungsten (green, red) and running about 25-30 cfh on your argon. Ball that end on the tungsten.
Oct 08, 2011 | Miller Electric Manufacturing Electric...
I have a miller microwave 200. what settings should i use for aluminum welding? dcep, ac, dcen? i'm using a3/32'' tungsten and trying to weld on 1/4'' alum plate. the weld is not turning out to be a smooth...
I think you mean you have a Miller Synchrowave 200.
Typically, you would want to use AC below about 250 amps. In this case (to keep it simple), use AC, adjust your balance to about 4, use an 1/8" pure tungsten, pure argon at about 20CFh, and set the panel at 170amps to get things started. For general purpose, use 4043 filler.
Now - these are just generic settings, but they will get you going.
Jan 12, 2010 | ARC Welding Secrets Book - Mig/tig/oxy/arc...
My webcam refuse to come on
Hi
There could be the problem with webcam drivers. To make it function properly you just need to reinstall the web cam drivers again.
First remove the web cam drivers from Add/Remove programmes under Control Panel.
Reinstall the drivers and try again to launch the appropriate application like chat messenger to test it.
Sep 18, 2009 | ASUS A6U Notebook
My tungsten appers to be melting when i am welding aluminum also leaves black residue when welding
TIG TORCH MAY NOT BE RATED AT THAT AMPERAGE .MIGHT BE BETTER TO USE 1/8 PURE TUNGSTEN. BLACK RESIDUE MAY BE CAUSED THE CORROSION OF COPPER GUTZ DURING WELING ,DO TO INTENSE HEAT. OR MAYBE CAUSED BY FAILURE TO CLEAN METAL AND/OR DIPPING THE TUNGSTEN.
Jul 02, 2009 | Miller Syncrowave 200 Tig Welder Cover...
Miller DYNASTY 350 TIG WELDER w/TIG TORCH 951074 Logo
87 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
