SOURCE: I have been using the Bible Library deluxe for
Bible Library Deluxe Special Edition Version 5.1
System Requirements
**We can only warrant and support our products when they are run using a computer for which they are designed.
Minimum System Requirements are the *very* minimum specs that your computer needs to run the software. If you try to use the program when your computer does not meet the minimum system requirements, you will experience a wide array of unpredictable results.
Operating System: Windows® 95/98/ME/XP
RAM: 16 MB
Hard Drive Space: 3MB Free
This is from their website,sorry but Win 7 is unsupported.
SOURCE: is there a version of Bible Library Edition
If a program cannot be run under Windows 7 because of compatibility issues, which is the case with Bible Library Deluxe Special Edition 5.1, you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
SOURCE: I am trying to install
I am told by the authors that 3.1 is not compatible with Windows 7. They suggest the most recent version.
Hope that's helpful.
SOURCE: My bible Library version 4
Download and install XP mode for your windows 7.
Link http://www.microsoft.com/windows/virtual-pc/download.aspx
