Question about Creative Labs Zen Micro MP3 Player
Mp3 player won't record plus some other defects
Mp3 player won't record. Will not shut off. When I reset it it says playbakc erroer. The thing is only 5 months old
  • 3 Answers
Try format and clean up in recovery mode.
if not, erase firmware and then reload firmware. but make SURE you have the installation disc first. as without it. there will be much pain and frustration(as i am having now)
Also, many bloggers have found that windows media player 11, especially beta version is causing problems. so rollback in add/remove programs to the 10th one and try it again FIRST!
Posted on May 25, 2008
My zen V plus is stuck in recovery mode. i cannot select an option or shut it off. how do i reset it?
try this: Find the reset hole on the side of the player just below the power/hold switch. Please do not mistake it for the microphone hole at the top. Then push a paper clip or something similar in the hole, and the player should automatically shut off. If your player does not shut off, you will have to wait for the battery to run out and die, but usually the reset hole works.
Aug 05, 2009 | Creative Labs ZEN V Plus MP3 Player
Mp3 players stuck on line in recording
I had the same problem. I opened my zen V plus and noticed that the recording switch did not have the proper tactile feedback, which means the spring is somehow jammed and the contact blade can open or close the contact randomly. I scratched away the top half of the plastic casing (which was abnormally soft) and removed with a tweezer the tiny blade that closes the contact. I refit the whole thing back together and it works fine. Obviously the voice recording function is gone, but personally, I don't care...ht tactile feedback (spring not working properly. So I decided
May 30, 2009 | Creative Labs ZEN V Plus MP3 Player
Zen V plus says processing while being stuck on line in recording
if it is stuck for about 30 min then u have to reset there's a small hole below the power,used paper clip to reset.
Rec. problem regarding
If I virus attacked your player (none has, I'm pretty certain) you could reset it. More probably your firmware or memory is defective and the only solution is to exchange it.
Oct 08, 2008 | SanDisk Sansa m250 MP3 Player
My Zen Nano Plus 1gb turned into a Zen STONE Plus??
Most probable that either you have downloaded the wrong firmware, or the website has an incorrect link. Make sure u select the right 1 and try again, hope it works (ps, in the url at the top of the page, it should link u to a page that says summet similar to the model of your player such as www.website.com/download/nano.zip as an example...
Jun 08, 2008 | Creative Labs Zen Nano Plus MP3 Player
Keeps going to recording
Try pushing down the reset button with a pin. You'll see the reset button right below the on-off slide (it's a small hole). Hope this works.
May 25, 2008 | Creative Labs ZEN V Plus MP3 Player
Can delete recordings
Try using the installed software to delete first. If that fails, use Windows Media Player. If that fails,
Possible firmware upgrade issue.
Reset first - located on side of player. If that fails, Creative actually has a step by step tool you can use at:
http://193.95.171.83/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=107,E=0000000000366987556,K=3577,Sxi=5,Kb=ww_english_add,VARSET=ws:http://us.creative.com/,Case=obj(26219)
May 13, 2008 | Creative Labs ZEN V Plus MP3 Player
May 09, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Vplus hangs while charging
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
May 29, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs Zen Micro MP3 Player Logo
29 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
