Question about Dishwashers
My Bosch dishwasher is not draining water and thus leaking on the floor. It is 7 yrs old but only has been used for 3 yrs as I was away. It was run weekly in my absence. Any ideas?
  • Dishwashers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 10, 2010
Water is not draining from Bosch Dishwasher 10 yrs old
Give this video a try. There are lots of places where gunk can build up and this video shows you how to do it on a Bosch dishwasher.
Dec 04, 2017 | Bosch 24 in. SGS43C12 Classixx...
GE Nautilis dishwasher has water collecting in bottom while not in use and leaking onto floor approx. 7 yrs old
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
Aug 10, 2011 | GE Nautilus 24" Built-in Dishwasher
Not draining and check water light on
you have a blockage in drain pump consult manual for cleaning process when water drained away check water light will go out.
May 27, 2010 | Bosch 24 in. SGS43C12 Classixx...
My bosch dishwasher started to leak. Why? It is about 8 yrs. old.
it depends on the location of the leak.check the seal, check to make sure the unit is draining,check to make sure the drain hose doesnt have a pin hole in it.
Mar 11, 2010 | Bosch SHU9915UC Dishwasher
GE Externa Tritan XL (7 yrs old): Standing dirty water
Hello, there isnt much that you can do, there could be a number of problems. It could be a slight blockage somewhere from your drainage hoses to your pump. It could also not be spinning properly. If you want to drain the rest of the water out you will need to get your drainage hose and lay it flat on the floor to a drain, this will stop things getting smelly. You just may have to get a repair man in, I hope this helps.
Nov 07, 2009 | GE 24 in. Profile PDW7800 Built-in...
Drain pump runs continuously. Nothing else happens!
Water had accumulated in the sump - a plastic tray at the bottom of the dishwasher which catches any leaked water. This operates a float switch which makes the drain pump run all the time. The fix was to tilt the dishwasher backwards to drain away the water. It isn't filling up again, so I'm not sure where the water came from, but I'll keep an eye on it!
May 17, 2009 | Bosch Dishwashers
Leaks, doesnt drain properly and cloudy film on glasses
u have water under dw .and overfill switch turninng on only  drain pump all time.second from bosch water  water never leaks on floor.
Sep 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher will not drain - causing moldy odor
Hello Mimhoff it depends on how much water is down there. The sump area always has a little water in it to prevent the circulation pump seals from sticking. Usually around 1 to 2 inches. If there is more than that, check the slots at the bottom of the sump on the left side for being clogged and check the end of the drain hose to make sure it is clear. If you are getting a moldy/odor from the dishwasher, try running Dishwasher Magic or Tang thru the dishwasher. This will remove any build up of food or detergent from the dishwasher. If you are running the dishwasher every few days and just scraping your dishes, then either leave the door ajar or run the rinse & hold cycle to help keep the odor down. Bosch doesn't reccommend running bleach thru the dishwasher as this can cause damage to the rubber seals. However 2 tablespoons of bleach once a year won't hurt.
Feb 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch SHU43
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door. Mine is a BOSCH 5316.
The draining problem may mean a clogged drain hose -- you have to check it all the way back to either the main drain or the garbage disposal (if you have one). This may be what forced off the impeller wheel.
Nov 15, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
140 people viewed this question
Top Dishwashers Experts
