Question about Toshiba Televison & Video
I need a scematic diagram for toshiba television model# 21N5XM i need to see what its the value of resistor R 327 or its ohms
MikeNJ1964
  • 398 Answers
SOURCE: Resistor ohm values??????
RK42 = 2.2 , RK46 = 1.5 , RK58 = 3.3 , RK52 = 1.8 , RK 50 = 2.2 , RK54 = 1.5
Posted on Aug 29, 2007
easyab
  • 132 Answers
SOURCE: TV set shuts down
3.9 ohm 2W
They are parallel in circuit and measure around 2 ohms when ok. Check the fuse associated with that circuit. FD101S 3.5 A
easyab
Posted on Aug 24, 2008
blueextc3221
  • 15935 Answers
SOURCE: How do you wire up 2 4 ohm dual voicecoil subwoofers for 1 ohm?
Both + on Both Subs to + Terminal on amplifier.
Both - on Both Subs to - Terminal on amplifier.
Posted on Jan 15, 2009
  • 5 Answers
SOURCE: Maytag Neptune MAH4000AWW
if r 11 is bad you should really check the bearing on the tub you will probably find it to be bad or going bad causing the moter to pull more amps causing r 11 to burn out.
Posted on Jan 23, 2009
SOURCE: burnt out resistor
I'm in the same fix. I learnt that a new pcb is £68 so had the pcb repaired but after the machine has warmed up it now cuts in and out. Like you, I haven't been able to locate a wiring diagram so am trying a last minute lash-up before binning the machine:
A friend suggested that since we all seem to only operate the cleaner on full power I should connect the on/off switch direct to the motor bypassing the rheostat and the pcb as in old fashioned machines.
Posted on Jul 07, 2009
Resistor value of R704 of Sharp tv model 21v-fk200m
How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
www.fixya.com/.../t25439922-unlock_sharp_crt_tv_model_21v_fk200...
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
Dec 28, 2015 | Sharp Televison & Video
Sir ihave toshiba t.v model 21n5xm ,,,,the STR -z4202a is not found here in jordan there is another no. for this STR
That is a specific I/c.
I have however found a supplier I hope it helps.
http://www.chinaicmart.com/series-STR/STRZ4202A.html
Jan 02, 2011 | Toshiba Televison & Video
Value resistor 719 of chasis serial : qpwbf9254mezz,tv sharp 27" model: 27j-s100 or diagram. thank you for his help
I looked at the same chassis I have and the resistor has color bands green blue silver gold wich is a .56 ohm 5% 1/2 watt resistor
Dec 03, 2010 | Sharp 27J-S100 TV
I have a Toshiba projection T.V, model number 43J7DM.It is dead
247 is .050 watt15K ohm
404 is 0,25Watt 1K ohm
420 is 0.5 watt 10K ohm
513 is 0.25watt 100 ohm
However if you dont understand them dont play around with them you may end up doing more damage than what you have now. If resistors blow then some other fault has caused excess power to fuse them and that takes knowledge of how to measure the current at each step. Some of these resistors are related to the power board. Getting circuit diagrams from toshiba is difficult Quite often there is a diagram inside the chassis of each model.
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Toshiba 55H70 55" Rear Projection...
Wires were cut and i put them back together, now the screen goes red and shuts off?
hello i cannot see this model number in this site..toshiba tv model number 21n5xm..
Jan 06, 2010 | Toshiba 51H84 51" Rear Projection...
Need info
I made a couple videos about reading and testing resistors. Keep in mind, if you're reading a resistor while it's still in the circuit, it might not read the value that it says on the resistor because of the circuit it's in. While in circuit it can only read the value of the resistor or less. If it reads more ohms while in circuit, then the resistor is probably open. My meter reads OUCH when it's open and 0 when it's shorted.
Feb 26, 2009 | Toshiba 43H70 43" Rear Projection...
Toshiba 42h82 convergence resistor and pico locations
(6) 1.8 ohm 1watt metal film resistors for R7711, R7716, R7721, R7726, R7731 and R7736 yes the STK 392-150 will work fine.
Sep 24, 2008 | Toshiba 57H82 57" Rear Projection...
Replacing Convergence IC's, I found a bad resistor needing replacment
They are both 1.8 ohm 1watt fusible resistors. Metal film 5% 1.8 ohm 1watt will substitue them
Aug 08, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba tw40f80, replaced both convergence ic's, power light still blinks
Solder yoke plug and vertical IC connections.....try again.
Let me know.....T.
BTW....Tosh recommends STK-392-110's replace with -110T's
Toshiba OEM.....then there is no question about resistor value
change......
Aug 03, 2008 | Toshiba TW40F80 40" Rear Projection...
PHILIPS 43PP920217 DPTV305 PROJECTION SET
those are 6.8 ohm 1watt metal film resistors 5% tolerance
Jul 22, 2008 | Philips 43PP9202 43" Rear Projection...
Televison & Video Logo
75 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
