Question about Ford Tractor Naa Golden Jubilee Emblem
Got a Ford Jubilee, that has had a lean run problem, was running ok and brushhogging the other day. It backfired pretty hard and blew black parts out of the stack, (new muffler, so doubt it was that) after that it won't run over 1200 rpm but Idles well and start up are great. Rebuilt the carb and put in new points. Messed with it a little yesterday moving the float level. Noticed that had a lot of foam in the radiator. Unit will not make power to go past idle or 1200 again. Would a head gasket disallow power or RPM? Need to get the old girl running as I need her in the field. Thanks. Jerry
  • 1 more comment
  • Ben Dover Sep 09, 2010
    hi Jerry, so not to waste your time or mine, what has been suggested already...copy and paste the previous failed solutions and we will go from there.
    bill
    bill
    bill
    President:
  • 1,111 Answers
Hi Jerry,
i tried to post a clarifacation request, but it wouldnt post, so not to waste your time or mine, what has been suggested already...copy and paste the previous failed solutions and we will go from there.
bill
Posted on Sep 09, 2010
    well thats fixya for ya...please forgive the multi post...it said id dint go thrugh
    bill
    thrugh means through....sorry can edit, just one of a thousand bugs on this site
O7 rhino 660 runs good,then backfires and stalls.starts every crank,but will run short time then stalls.does not backfire everytime.seems like it runs longer when it sets couple of days.
I would overhaul the carby and check for corrosion in the main jet and other circuits
if it is a 2 stroke I would check the crank shaft seals as they may be hard and leaking mixture and running lean ( backfiring)
Oct 11, 2015 | Rhino Motorcycles
Wont start backfires
These have a problem with developing a crack in the heavy rubber intake between the carburetor and engine. Once the crack opens up, the engines runs much too lean (sucking in extra air through crack). Not too hard to replace and part is readily available at most Polaris dealers.
Aug 19, 2014 | Polaris ATV
Single cylinder yanmar diesel engine on log splitter back fires out of exhuast & blows out black smoke
Engines runs for a couple of seconds then loudly backfires with a flash of flame out of the exhaust followed by a plume of black smoke. Then runs sort of ok for a couple of seconds then repeats the backfire again AmanStino Lightning Cable Apple MFi Certified 1M Nylon Braided Charging...
Apr 21, 2012 | Cars & Trucks
I bought a 89 ford bronco it will back fire through the fuel injection when you give it gas but not all the time
sounds like it is running lean. Check engine light on?
You mean backfiring through the intake manifold right?
A tip in hesitation or backfire is usually a lean condition. If you have a MAF sensor, clean the inside exposed wires with carb cleaner. Do no touch.
Mar 06, 2011 | 1989 Ford Bronco
I have a 1978 ford inline six has a newer holley card having hard time adjusting it. Runs great at lower rpms and idel but when you drive it loses power and backfires.
As you know, you have one of two things going on. it is running too rich or too lean. Run it hard for 15 minutes pull the plugs and check for black, wet looking soot = rich. Brownish, whitish dry looking soot = lean. Be sure your vacuum advance on the carb is hooked up to the proper port. Check the full advance of the timing with a light to be sure you have proper advance during rev up. You want 22 degs. full advance. If you have a pull choke try to close the choke to see if that will level out the hi end. If that works you are running to rich. adjust as necessary to lean it out. Too big a carb can also be your problem. For the best carb to engine size double the cubic inch of you engine. If your engine is a 290 ci you max size carb should be approx 550 cfm, Now if you engine has a hi rpm cam profile you have to factor in needed cfm at hi rpm. Thats why such and engine for racing will not have good bottom end or low rpm power. Sounds like you have just the opposite going on. Which can still be caused by a over sized carb. Too much fuel not enough air or room in the engine to burn it.
Sep 04, 2010 | Ford F-150 Cars & Trucks
Backfiring on deceleration from exhaust pipes
May be running too lean or too rich. Check the color of your plugs, black dry and sooty means they are rich, white with blisters lean.
Apr 03, 2010 | 2005 Honda VTX 1300 R
Carb is acting weird cant seem to adjust
That is the choke adjustment,have you checked your timing on the motor and check and see if the vacum pod on the distributer is working. also check your vacum lines for any tears or cracks in them.
Mar 29, 2009 | 1984 Ford F 150
Ford Tractor Naa Golden Jubilee Emblem Logo
339 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
