Question about Epson (ELPLP25H) Projector Lamp for EMP-TW10
The picture is green can i adjust this - Epson (ELPLP25H) Projector Lamp for EMP-TW10
  • 35 Answers
There is a color temp adjustment within your menu. I doubt that will solve the issue, however, Your problem is more than likely a defective LCD panel.
Posted on Oct 27, 2010
How do I adjust the color
Hello
To adjust colour and other picture adjustments
[1] Press "Menu" key to display the main menu.
[2] Use cursor UP/DOWN keys to hilight [green]; Picture or sound ; whatever you wants to adjust, and press ENTER.
[3] Use cursor UP/DOWN keys to hilight [green] AUTO [for factory settings] or MANUAL to set picture settings according to your taste. Here you have to hilight MANUAL as you wants to set it mannualy. Press ENTER after selecting MANUAL.
[4] User cursor UP/DOWN keys to select the option you wanted to change.
then cursor keys to make adjustments of the selected option parameter according to your taste.
[5] When you have finished all the adjustments according to your taste, press EXIT key to return to normal tv viiewing. This way you can adjust the sound parameters also. Proceedings are all the same, but the option choose to hilight [green] must be sound. That is all. Ok.
Jan 12, 2011 | Sanyo DP26746 26 in. LCD Television
Green picture
Possible needs color tracking adjustment done by shop.
Apr 18, 2010 | Samsung HLN437W 43" Rear Projection HDTV
your picture tube is wearing out . there is a way around it it will work for a while .you need to lower the drive for the green . on the board on the neck of the picture tube there are three adjustments marked red , blue, green on the front of the tv turn down the color all the way down . normally you would have a black in white picture but now you have a green and white find the screw adjustment marked green and carefully turn it down untill the picture is black in white and your fixed . adjust color back up .... dont do this repair unless you are confortable working around high voltages a wrong move inside a tv can kill you , this adjusment must be made with power on so you can see the picture as your going ... so this may not be for you . use your own judgement ........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 26, 2009 | RCA Televison & Video
My screen turns green and then turns off
you need to adjust the screen voltage. behind the front grille and inside cover. a small black box 6 adjusters protruding from it. only adjust the the color counterclockwise that matches the problem in this case it's the green so look for the knob with "G" marked by it. there are 2 with "g" marked by them the row across the top of the box are for focus don't adjust. back the knob off untill the raster is blank with your input set to an inactive input, the picture should be blank and black.
when it is you have the adjuster close to where it should be, now change the input to an active signal and turn the color off so that you wil have black and white picture. adjust that knob untill you do have a truely black and white picture not too green or red or blue. go back to inactive video input and check that there are no lines of any color on the screen. repeat if needed. always adjust these knobs slowly the set will be watching you ! if your autofocus won't work now you have the adjustment set too low. check this function before putting back together again. these adjustments can be real touchy so be patient
Feb 20, 2009 | Sony KP-57HW40 57" Rear Projection...
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Green is going, going, gone?
I would suggest check the the secondary side of the power supply for around 130VDC if that voltage is found to be lower than 120VDC I would suggest to replace CP80 with a 100 mfd@250 vdc. Part # 218374
Check Globalsemi.com for these parts.
Jan 13, 2008 | RCA F36650 36" TV
Green picture
I'm not sure about this model but most projection tv's have a focus/screen control block usually located behind the front grille where the speakers are. The grille usually comes off easily. If there are no circuit problems you can adjust the red green and blue picture tubes there. Also the focus. It will be written somewhere screen and focus: Three for screen and three for focus. If you find the screens then adjust them slowly clockwise for increase brightness on the red and blue and you may have to reduce the green. Adjust for best picture. If the picture does not adjust too good then the tubes are weak. Only if there are no circuit problems Hope this helps
Dec 30, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Picture has a green outline
your convergence ic's and possible low ohmage reisistors are at fault.there the large ic's that start with stk
Sep 10, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Green Picture.
i suggest to have it check by a qualified service technician. there seems to be a problem with your crt (cathode ray tube). because inside this projection tv are 3 crt guns responsible for color red, green and blue, which only qualified technician can adjust it and replace if it is necessary.
Jan 15, 2007 | Philips 55PP9701 55" Rear Projection...
Epson (ELPLP25H) Projector Lamp for EMP-TW10 Logo
100 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
