Question about Acer Aspire 3000 Notebook
All of a sudden" going into hibernation"
Acer 3000, working fine, all of a sudden, went to hibernation mode and shut itself down. Only lights come on is the two on the front flash when you press power, power light does not come on, fan does not start,,,19v of power coming out of power supply, any ideas
  • denroywynter May 21, 2008
    My acer laptop has just switched itself off and the on/off button doesn't seem to respond at all. This proplem occured when mobile phone was plugged in.
  • skippydeano Jun 07, 2008
    first symptom was "loading windows settings" never got to log on screen. Did hard reset. turned back on and only power led on front blinked yellow as if unit were in standby. battery led does not light at all. tried removing & replacing battery but unit just started same routine. tried a second power supply. no change. tried to boot from cd but same thing. only way to turn off was to press the power button and unit switches off immediately. press power button and unit immediately does same routine. unit is acer aspire 3003 and has been ok until now. please help.
Dear Guys
Thanks very much for your help. Problem solved.
Very best regards.
Denroy Wynter
Posted on May 26, 2008
  • 121 Answers
Try to open ur laptop cover .
on the mainboard there is usually a jumper located near the cmos battery. try to change its position for 3 seconds and return it back to its normal position.
this way u will clear the board memory .
start ur computer and load default settings.
hope this will help.
Posted on May 24, 2008
Hi I have a dell dimension c521 worked fine when I got it all of a sudden it went into hibernation , how do I bring it out of hibernation ?? Can anyone please help me thanks ..
a suggestion remove the electrical cord and shut down PSU.for 5--6 hours.then take away hiberfil.sys and get same extra GB.
May 28, 2013 | Computers & Internet
Acer Aspire 7000. Power light comes on and stays on. HDD light flicks twice then goes out. No noise or screen change. All dead. Think I may have hibernated it last shut down. Removed power supply and...
If the laptop is in hibernated mode, if and when it comes on, go into power options select hibernate and uncheck box to the left to disable this feature and click apply.
Jun 03, 2012 | Acer Computers & Internet
My Acer Aspire One went into hibernate mode by itself and am unable to turn it back on unless I remove the battery and use it solely on electricity mode. Please help.
keep press power button for 1 mins and your laptop will turn off. when you turn on your laptop. disable hibernate mode.
to return to your desktop from hibernate mode press power button quickly. windows will resume
May 04, 2010 | Acer Aspire One PC Notebook
My Acer One Aspire is stuck in hibernate. After it updated itself and said it was preparing to shut down, it was stuck in the preparing for shut down mode for hours. When I let the battery run down to turn...
This solution may sound stupid, but it is affective. Try to press really long time (about 1-2 minutes) on the power button of the laptop. wait for it to shut down completely. Then turn it on to see what happens.
What may have caused this is an update of any sort.
Nov 11, 2009 | Acer Aspire One PC Notebook
Unit Always Shuts Down While In Use
all the laptops on the world have warm problem. if you use your notebook dirty place your fan could get dirty and not working well and not makes cool anymore. in warm system can shut down itself. it is often does. if you open your laptop back case you will see the fan. there are olny 4 screw. clean the fan and screw again. try it.
sorry for my enghlish.
May 17, 2009 | Acer Aspire 7720 Notebook
How do you get an acer out of hibernation?
If it hangs in hibernation the only way to get it out is to hold the power button down until it shuts off, and reboot. If it continues to hang up in hibernation, do a system restore o system repair with the recovery or operating system disc. If the problem persists after the restore or repair, then you will need to disable the hibernation.
Jul 25, 2008 | Acer Aspire 3000 Notebook
Auto hibernated, will not power back up
It's possible that the laptop is stuck thinking it should be resuming from standby but cannot find the data in memory. Remove the battery, unplug the power cord, and hold down the power button for at least 10 seconds. Then plug JUST the power cord back in and try to boot the system. If you still get no response then it's possible that one of your RAM sticks is going bad. With the battery and power cord removed try removing both sticks of RAM. Then try to boot the system again with only the power cord in use and no RAM installed. See if you get some sort of response from the BIOS. Hold down the power button to turn the computer off again, remove the power cord, and then try booting the system with just one of the memory sticks installed. If you can isolate one of the sticks as causing the failed boot, then that stick is most likely faulty.
May 13, 2008 | Acer Aspire 3000 Notebook
My laptop turns on itself, i don't know what's causing it. my windows(service pack 2) is fine and running smoothly....
Go to control panel. Power options and there u can see hibernate. enable hibernate and click apply. and come out and go for shut down and there u can see stand by shutdown and restart. then press shift button on keyboard the standby turn on to hibernate. then click hibernate it will shut down the entire system within 10 to 15 Sec try this. and Mail me on this mail ID
Abhilash_Aditya25@yahoo.co.in
Dec 19, 2007 | Compaq Presario X1000 Notebook
Acer Aspire 3000 Notebook Logo
153 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
