1991 Geo Storm Logo
Posted on Sep 07, 2010
I am having trouble with radio wiring cant seem 2 figure out the color codings
Thomas Dean
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Nov 14, 2010
Thomas Dean
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
Helped
982
Points
10
2007 FORD EXPeDITION RADIO WIRING COLORS
Question edited for clarity and bad spelling of 'Expedition'.
Question moved to model category.
Quit typing in all CAPS, it is considered SHOUTING and RUDE. It is also harder to read!
This seldom works, and the reason is because the radio system and steering wheel controls are monitored and operated by the Body Control Module on the 5 volt Can Bus System. When you connect your new Android box, the computer won't have a clue what is going on! Be prepared for a whole heap of trouble.
2007-10 Ford Expedition AE Page 1
Scosche https://www.scosche.com > media > guides
Brown/Blue. Below Radio Behind. Speaker Amplifier: Radio Bezel. Page 2. VEHICLE DISASSEMBLY. REAR DOOR SPEAKER. RADIO REMOVAL. FRONT DOOR TWEETER. FRONT DOOR ...
3 pages
2007 expedition, stereo wiring - the12volt.com
the12volt.com https://www.the12volt.com > installbay > forum_posts
Aug 3, 2007 - As a follow up for those interested in the future: Steering wheel control wire is pin 18 on the ford 24 pin harness as seen in this diagram ( ...
2007 ford expedition radio - the12volt.com
Dec 1, 2007
2007 Ford Expedition, OEM Amp Pin Out - the12volt.com
Nov 6, 2021
2006 Ford Expedition stereo wiring - the12volt.com
Jul 31, 2006
2015 Ford Expedition EL Stereo Wiring Diagram - The ...
Aug 28, 2015
More results from www.the12volt.com
Wiring Diagrams, Radio Pinouts Ford Expedition - Page 5
Ford-Trucks.com https://www.ford-trucks.com > forums > 902530-wirin...
Oct 31, 2019 - I'm having a terrible time identifying what wire is what. Colors I have do not seem to match any thing I'd read. Any help would be appreciated.
Wiring Diagrams, Radio Pinouts Ford Expedition - Page 4
Oct 18, 2018
02 ford expedition xlt stock radio wiring diagram
Apr 10, 2017
Nov 16, 2009
2009 expedition audio wiring color code
Apr 13, 2017
More results from www.ford-trucks.com
2answers
Where can I get a radio wiring diagram?
Radio wiring color codes, radio wire color codes, radio wiring diagram, radio wire diagram, radio wiring harness, radio ...ā€ŽRadio Wire Harness and Colors - ā€ŽInstall Dr: Nissan Wiring
1990 toyota corolla stereo wiring codes i just purchased a sony stereo and i took out the old radio in my 1990 toyota corolla but i cant figure out how to connect the wires i need the color code for...
what you need is to buy a wiring adapter for your car.it only cost about 15 bucks and plugs right in to your original plugs that were connected to your factory radio.the great thing about this adapter is that you dont hava to cut your original plug off just in case if you ever want to reinstall your original back.also the wires that go to your new headunit are color coded to match the exact colors that you connect to your stereo.you can't mess your connection up because all you have to do is connect each wire to the right color,tape them up,connect your stereo and you have music with all of your speakers working like they should and without any headaches.i hope this info helps.take care and good luck, manny
I cant figure out how to hook up my new raido in my car can u help
The easiest way it to get a wiring adapter, any auto parts place or even walmart sells them in the automotive radio department. They plug into the factor harness connector, but you will still have to splice the adapter to the new radio harness, but the wires will be color coded the same at the new harness.
I am trying to install a new raio in my car but I cant figure out which wire is which. The wire colors are blue, yellow, brown and a light blue or grey.
well sometime's it's all color coded so the new radio should have the same colors. first get the speaker wire's situated and the go from there. after that you only have power, ground, ingnition wire, so it turns off when you turn you car off.
Color codeing of 1985 ford tempo
should be a red for hot black for ground yellow for memory and blue for amp remote. the rest of wires are speaker wires. match wires with car radio has a pair of wires for each speaker. like tan for positive tan with stripe on it is ground.
Removing Factory radio
first remove the instrument panel cover 2 screws by speedometer then carefully pry it out 4 screws hold the radio in thats it wireing colors can be found online im sorry i dont remember the site
Top Geo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Geo Expert? Answer questions, earn points and help others
