Question about LG 52SX4D 52" HDTV
Lg 52sx4d problem
i have a problem with my lg 52sx4d dlp tv. when turned on, the red light continues to flash and the white scroll lites roll for a few minutes. it then shuts off and about 5 minutes later, trys to turn itself back on and again does the same thing. please help if you know what could be causing this as i dont want to pay to replace a bulb if that is not the issue.
thanks,
adam
  • 3 more comments
  • freez65 May 17, 2008
    The same problem as Adam
  • MikeDever May 18, 2008
    I have the same problem also, I just tried to replace the bulb but it's still giving me the same problem.
  • harderstylez Jun 11, 2008
    i finally got it to work but now it works for alittle while and then when i go to turn it back on later, it is like it shorts out and the screen is very warped and turns different colors. if i continue to try and turn it back on and hit enter and mute a few times... then it shows the picture normal. it did this a few times and now it wont come on.. i think there might be a short in some of the electronic boards.
  • Anonymous Aug 20, 2008
    we read this post, and have replaced the bulb as others have indicated, but the TV still just cycles through the lights and won't come on. And I fully reassembled the TV. What other problems are there?
  • bignorm13 Oct 08, 2008
    I have a very similar problem, but is very random. It may work fine for a couple days and then one day it may shut off only once or other days it continously does it, then the next day is fine. The bulb was replaced 2 months ago. It will power off, red light blinks 3 -4 times, then the white light turns back on. Sometimes the light will go completely off for a 10seconds-1 minute before powering back on. Very random and very frustrating.
If the red light scrolls through, you need to replace the bulb. I replaced the my own bulb, and when I tried to turn on the tv the light kept scrolling. What was wrong? I DIDNT FULLY REASSEMBLE THE TV AFTER REPLACING THE BULB.
Make sure that all the screws are put back in and it will probably work if you have replaced the bulb.
Posted on May 24, 2008
If you have replaced the bulb (with a LG/Zenith/Phillips brand) and not the Osram or other aftermarket bulb, you probably have either a weak ballast, dirty fan, or weak fan... check the fan 1st, use a can of comressed air DO NOT BLOW INTO THE UNIT, open the bulb access door and blow the dust out...
Posted on Sep 06, 2010
    Problem Solver:
  • 11 Answers
There is a capacitor in the power supply that goes bad about every two years that that is what usually causes it!!
Posted on Aug 30, 2012
Adam have you had any luck fixing your problem, as I have the same problem.
Scott
Posted on May 17, 2008
  • freez65 Jun 01, 2008
    thanks for the help . up n runing
    Welcome Back:
    Visited the website for 2 consecutive days.
Same problem here. This doesn't sound very encouraging.
Posted on Sep 03, 2008
I replaced the lamp for my LG 52sx4d DLP television. The TV still wont turn on and has a red blinking light where the green lamp indicator should be. How do i get my tv to turn back on!
did you get a Philips lamp check that also make sure all the doors are close also you could trouble shoot more with discount merchant
Sep 13, 2011 | LG 52SX4D 52" HDTV
Lg 52sx4d not starting up
The flashing green bulb light means the access door for the bulb on the lower right side of the TV is open or loose. There are two screws that hold it in. If they are tight, maybe the interlock switch is bad or disconnected. Open the door, and hold in the little white interlock button while turning on the TV. If it still doesn't work, there are wires leading from the switch to a connector about halfway across the TV on the bottom. Connector might be loose. Unfortunately, it is hard to reach. You might have to remove the screws across the bottom rear edge that hold in the chassis and gently slide it out to reach the connector.
Mar 01, 2009 | LG 52SX4D 52" HDTV
LG DLP not turning on
well i know what the problem is... if your getting the white scroll and then the red light flashes but the fans are comming on and you got a new bulb the broblem is the ballast. i know cuz i had the same problem and a good friend of mine has a tv shop and i had him look at it but the good news is that its not that hard to change. if you try to go through LG thay wont be able to sell you the ballast if your just a coust. good news is that you can fined the ballast on ebay from s.gifeasywaylamps its about $130.00 bucks shiped. bad news about is that thay are from china(it is where i got mine) but it works great and hasent gave me a broblem yet. if any one eles has the same problem and it was something eles.... PLEASE POST IT. i hope my info has been helpful to someone.... thanks Brad Ross of East Moline Illinois... you can email me at plopit40@yahoo.com
Nov 11, 2008 | LG 52SX4D 52" HDTV
Light bulb flashes 3 times, TV won't turn on
well i know what the problem is... if your getting the white scroll and then the red light flashes but the fans are comming on and you got a new bulb the broblem is the ballast. i know cuz i had the same problem and a good friend of mine has a tv shop and i had him look at it but the good news is that its not that hard to change. if you try to go through LG thay wont be able to sell you the ballast if your just a coust. good news is that you can fined the ballast on ebay from s.gifeasywaylamps its about $130.00 bucks shiped. bud news about is that thay are from china(it is where i got mine) but it works great and hasent gave me a broblem yet. if any one eles has the same problem and it was something eles.... PLEASE POST IT. i hope my info has been helpful to someone.... thanks Brad Ross of East Moline Illinois
Aug 30, 2008 | LG 52SX4D 52" HDTV
Won't turn on, just white light scroll then off.
I am having the same issue were you able to find a solution?
Jul 14, 2008 | LG 52SX4D 52" HDTV
LG DLP 52SX4D/Will not power up
Ours did the same, it was the colour wheel in the tv, it was stuck [from dust and smoke] and the tv wouldn't go past that problem.
Jan 19, 2008 | LG 52SX4D 52" HDTV
LG 52SX4D 52 in. HDTV Television
 have had this problem several times i think this is a manufactures default. i am in the proccess of contacting the manufacture email me we can talk aj@metrogeneral.com please let anyone else who is having this problem contact me as well.
Aug 04, 2007 | LG 52SX4D 52" HDTV
No picture
set is gone it shut down,call local service dept.
Apr 12, 2007 | LG 52SX4D 52" HDTV
Open Questions:
See all LG 52SX4D 52" HDTV Questions
LG 52SX4D 52" HDTV Logo
538 people viewed this question
Computer Repairing
Computer Repairing
