Question about Frigidaire Refrigerators
Freezer is working but not refrig - Frigidaire Refrigerators
  • Frigidaire Master
  • 8,220 Answers
What you have is a defrost problem most likely. Look on the service access panel in the freezer for a sign of frost. If you see any then iside the evaporator is a coil plugged with ice. freezer is working but not - 736df80.jpg373dff1.jpgIt takes a bit of work with a hair dryer or simply unplug the unit and let er thaw out. The defrost system has 3 components. A timer or adc auto defrost control), a heater, and a Heater termination thermostat. One or more of these components have failed. More Here
Posted on Sep 07, 2010
Refrig was clicking on and off now nothing not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | Frigidaire FRS26H7CS Side by Side...
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Side by Side refrig. - Freezer not working but refrig. is
could be many thing , low on freeon also defrost problum , open panel of your freezer side and check coil behind it
Feb 13, 2009 | GE GSS25LGM Side by Side Refrigerator
Outside of refrig/freezer hot
Heat exchangers for rejecting heat to air are built into the outside walls. This is normal. Just make sure you have enough clearance for free air circulation around it.
Apr 20, 2008 | Nor-Lake Norlake Refrigeration 4' x 6'...
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Apr 06, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Refrigerators Logo
87 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
