Question about Amana ARB8057CSL Bottom Freezer Refrigerator
Bad water valve?
I'm not sure what a bad water valve is or where I would look. It worked for 3 or 4 days before crapping out.
  • marathonr May 14, 2008
    Will it be obvious if the valve is bad? Sorry this is all new to me. I'm not very good with things like this (obviously). Thanks!
  • 117 Answers
Behind the ref at the botton
Posted on May 14, 2008
Whirpool ice machine not getting water
If your certain the line isn't frozen. Then your valve is bad
Apr 20, 2015 | Whirlpool Refrigerators
I have a 1997 toyota tacoma that the heater works sometimes but not other times?
heater, totally dead.
1: blower working and blowing cold air ,
2: engine holds 180F or more all the time, HOLDS !! i use an IR pyro gun to do that as dash gauges suck.
3: heat lever bad, slipping or stuck (look)
4: some cars have no water valve, so use damper , it can stick closed.
if engine coolant was hot at heater failure we can work this easy.
yes< then is both heater hoses hot touch , fan on, engine hot.
see them as they enter fire wall, on both sides.?
you can in fact feel them on all cars.
ever do a real RAD cooling system flush , if not, BINGO, full of crap inside.
Dec 11, 2013 | 2007 Toyota Tacoma
How do I check the anode on my bock 32E water heater? I have flushed the tank several times but the water is still brown and now the release valve drains the whole tank every few days.
1) Anode rod is located on top of water heater.
It is 1-1/6" hex head.
It might be under a plastic plug, or you might have to take off metal top of tank.
Sometimes you cannot remove anode rod because it is rusted too badly.
I have used impact wrench sometimes and been unable to budge them.
2) Open following links for anode illustrations and resources:
http://waterheatertimer.org/Replace-anode-rod.html
http://www.thisoldhouse.com/toh/video/0,,20047047,00.html
3) Rusty water implies that anode is bad.
But water released by TP valve implies overheating, or bad TP valve.
4) Replace TP valve.
http://waterheatertimer.org/How-to-replace-TP-valve.html
5) Check your burner and combustion parts for orange-or-yellow flame and sooting on parts that implies the water heater needs to be cleaned. You do not want overheated combustion chamber to cause ECO event that might require new gas control thermostat.
Gas should burn with clear blue flame.
6) Overheating tank can also imply that gas control valve thermostat is not working correctly and may soon fail. This would be evidenced if water is very hot and new TP valve doesn't stop hot water release.
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | RTO Bock Water Heaters 32E 32 gal 104,000...
Hot water continues to run want cut off
Must be a bad water valve. Get it to day for $40 The chances of it being in the control or water level switch or temp switch is slim. Bad water valve. One way to prove it to be bad is to unplug the washer. If the water still enters then it is the water valve for sure.
Jul 04, 2011 | GE WJSR2070B Top Load Washer
My water located inside the fridge is not working, changed the filter, lowered the temp, checked the cable, ice maker is working. What could be the problem?
bad water valve,the water enters in the back and then there are two valves,one for the ice maker and one for the drinking water but you have to buy the whole valve to repair it,you just can't replace the valve for the water.call your parts store,give them the model number off of the machine and they will sell you the correct valve,either the solenoid is bad or sediment is in the valve.did you check to make sure the line isn't frozen?under the freezer door there's a connection that you can separate the water line,when it's appart hit the water,if water comes out of the line then the water line is frozen in the door and you can hit the door with a hair dryer or turn the temp.up to make it a little warmer in the freezer and after a couple of days it should work,if no water comes out bad water valve.hope this helps.
Jun 21, 2011 | Kenmore Refrigerators
My 1/2 hp flowtec pump keeps acting up worked great for 2 weeks Then I replaced pressure switch worked for 3 days then changed plastic hose to switch worked for 1/2 a day. Will not shut off
Three things to check
1. There may be getting sediment in the water line to switch. Flush the well tank at the boiler drain to see how much sediment (if any) comes out. Flush well if heavy sediment and call Well company.
2. Make sure the check valve is OK also.
3. If the impeller is bad on the pump it will not build pressure and keep running.
4. The well may be going bad, low volume. Call well company.
RJ
Jun 21, 2011 | Flotec Corrosion Resistant Shallow Well...
The ice maker backed up and put extra ice on the back of the freezer causing ice tray to stick out and freezer did not close. Pulled extra ice out and closed freezer but freezer is working (2-3 days the...
Hi and wlecome to FixYa, I am Kelly. You really have 2 problems.... 1 the inlet water valve has failed causing the water in the ice tray. The only remedy for this is to replace the inlet water valve. If you can squeeze the rubber fill tube at the back of the icemaker and it is / was frozen solid the inlet water valve is for sure bad.
Turn off the water supply to the ice maker until the water valve is replaced or the current problems you have WILL repeat.
The other problem you have is due to the door being open the evaporator coils iced up big time and the normal defrosting process is not removing all of the ice. Unplug the unit and direct a fan into the freezer compartment for just over 2 hours with the freezer contents removed. While the unit is manually defrosting... open the back of the unit by removing the lower fiberboard cover and clean the condensor coils and fan along with the drip pan / tray.
After 2 hours clean up the water mess and return the unit to normal service. It should work just fine.
Thanks for choosing FixYa,
Kelly
May 25, 2011 | Kenmore Top Freezer Refrigerator
We find water standing in the drum days after we wash a load. it isn't there when we unload a wash but shows up later. it reeks of sulphur. is the motor on the water pump going/gone bad? it works during...
Turn off the water supply valves behind the washer after you complete a lod. If there is no water in the tub a few days later, the machine has a bad internal water valve.
Oct 20, 2010 | Washing Machines
Ice dispensor not working
Most likely reason water not dispensing out door 1) You can turn up the temp in the freezer to see if it thaws in a couple of days, 2) Turn on the dispenser light and leave it on, will thaw the line and keep it thawed, 3) the water tank is frozen in the fresh food side (you can defrost with a blow drier) 6) the fill valve went bad or plugged ( power to fill valve but not opening) ($50) 7) Micro switch went bad in the dispenser for the water side 8) Door switch bad 9) Install a heater kit to thaw the line and it will keep it thawed ($35) PN#1381601 10) You can replace the whole door if insulation gone bad in door ( $500 to $800) 11) a broken wire to the fill valve ( no power to fill valve ) 12) with GE refrigerator bad dispenser boards or control boards ($400 and $150) 13) plugged, faulty or incorrectly installed water filter let me know more about you problem and I can help..
Sep 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a Maytag RSW2400 Frig. I just replaced the Dual Water Valve kit.(12001415 kit) I have water going up the the back of the frig. but not into it.I tried to blow air through it but it seems to be...
Sep 26, 2009 | Refrigerators
Amana ARB8057CSL Bottom Freezer Refrigerator Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
