Question about Dell PowerEdge 1600SC Server
Having a raid 5 problem, either in raid controller or raid cage backplane. Can it be fixed and what is the price.
    Problem Solver:
  • 12 Answers
What is the problem? If you give a more detailed question we can give the correct advice!
Posted on Sep 09, 2010
Disk 4 "is not ready"
> it does detect it on controller initiation.
Even when the drive is not spinning, it will identify itself (manufacturer, capacity) when queried. So, it's possible that it "checks-in", but files/directories on it cannot be read.
Apr 04, 2015 | Dell PowerEdge 2600 Server
Raid configuration
That's probably because RAID 5 only tolerates 1 HD failure, (unless you have hot spares, in which case you can have many failures -provided only one fails at the same time...).
RAID 5 arrays can tolerate no more than one member drive failure.
Nov 08, 2013 | LSI Logic Computers & Internet
Raid 7k controller not responding properlly error 2807
This could be an issue with the Raid backplane. If under warranty I would replace the backplane.
Even if no warranty you might be able to find one cheaply used.
regards,
Mike
Oct 10, 2012 | IBM X236 Server
Hi, within the previous 12hrs my e-series server bombed out - there are two issues (1) Memory DIMM malfunction (2) serveRAID-7k error 2807... I removed the faulty memory DIMMs, but the RAID error still...
You can recover RAID data from hard drive with RAID recovery software easily.
Tenorshare Data Recovery Enterprise is a comprehensive data recovery software that supports RAID recovery for RAID 0 and RAID 5. Lost data in RAID 0 and RAID 5 can be deeply scanned and restored immediately. Meanwhile, files and folders in RAID 0 and RAID 5 can be copied to other partitions directly. http://www.any-data-recovery.com/product/datarecoveryenterprise.htm
Aug 29, 2011 | IBM ServeRAID-7k Controller (71p8642) SCSI...
Not getting a drive letter from Compaq SCSI RAID setup
Did you see any new drives in the disk managemen screen? To get to the disk management, hold window key down and hit 'R', then type diskmgmt.msc and hit enter.
If you do see the drive in the lower half of the screen, you need to initialize the drive either as dynamic disk or basic disk. Then you need to add a new partition and format it.
Good luck.
Jul 04, 2009 | Compaq (128293B21) (128293-b21) SCSI...
Raid 0 on Intellistation 6221?
That particular work station comes with both IDE and SCSI drive interface controllers. The IDE drive should be used for your OS. The SCSI drives for your data storage. Now, the issue is to get the SCSI to work in RAID_0 as I understand.
You iwll need a RAID controller such as Adaptec AHA-3940AU WD SCSI Host Controller, which may be found on eBay (used) for a very affordable price. The driver software may be downloaded directly from Adaptec, so I suggest you do that in the iterim peroid, and store drivers on a USB thumb drive.
Hope this helps you.
Dec 21, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
Problem with creating array
The Perc RAID controller in a 2600 doesn't support RAID 4.
You can do RAID 0, RAID 1 and RAID 5.
With 3 HDD's your best bet would be a RAID 5.
Mirroring is RAID 1 (which would only use 2 of the drives)
Aug 31, 2008 | Dell PowerEdge 2600 Server
Raid 5 crashed
Hi Chris,
How many drives are part of the array and what type are they? Are the drives making any unusual sounds like clicking or screeching? If not, then you should be able to recover the data. If the drives are making clicking sounds, you will probably need a professional data recovery service that specializes in Raid 5 data recovery to help you.
If the controller shows that only 1 drive is bad, you should be able to rebuild it by replacing that drive. If the controller shows all the drives are bad, then it is most likely a problem with the Raid 5 controller itself. In this case, you could try putting the drives in a working version of the same enclosure/controller.
Check the obvious also, like loose connections to the drives. Whatever you do, dont force a rebuild as this will probably result in permanent data loss.
Wesley Gill
Gillware Inc.
Raid Recovery Info
Aug 28, 2007 | D-Link DNS 6040M (DNS-6040M) Hard Drive...
IBM 61H0031
have you installed the drivers for the raid controller that allow you to see the disks and if you have then the disks not getting enough speed check in control pannel and Administrative Tools Computer Management then disk management and see if their there. hope this goes well
Mar 16, 2007 | IBM 61H0031 - Drive Cage Drive Case
Dell PowerEdge 1600SC Server Logo
81 people viewed this question
Alun Cox
