Question about Admiral 18 in. DWCA500AA Free-standing Dishwasher
Not draining complety - Admiral 18 in. DWCA500AA Free-standing Dishwasher
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 07, 2010
I have 2002 Kia Spectra after engine shut down the fan motor is running so long that it draining the battery. It does not shut off before the temp gage is all most complety cooled down. Do you have any...
The fan should shut down after the radiator temperature is between 180-195 degrees. If yours is staying on way below this I would think you temp. sensor is stuck and keeping your fan on.
Feb 03, 2012 | 2002 Kia Spectra
Put new battery in votls are droping down to 10.3 if it was the alternater then why wouldnt it drain complety out
If new battery drops to 10.3 Volts on the dash monitor battery voltage, then the alternator is probably not charging it enough to maintain 13.2 to 14.2 volts when the car is running.
If it's the alternator, eventually all systems will shut down as it runs.
10.3 V is really low for a new battery.
Aug 01, 2010 | 1997 Cadillac DeVille
Error code FL and does not drain completly
most probably needs the water pump replaced.  not hard to do if you are a little handy..  there were a lot of problems with this machine regarding the water pumps.
Jul 22, 2010 | Kenmore Washing Machines
What is the oil capacity in the crankcase of a 1993 800cc intruder. How much do you fill it too? I stuck my finger in and got no oil and there is no measure dip to tell.
holds 3 us quarts of oil with a oil filter change or if the egine was complety drained after overhaul it takes 3 1/2 us quarts of oil.
To check oil look for a small quarter size window on the clutch case,oil level should fill half the window to be full.Bike must be held level while viewing window,not on kick stand.
Jun 10, 2010 | 2002 Suzuki VS 800 Intruder
My psp screen is complety black and i can hear
The screen will need to be fixed. We can certainly help you with this. Contact Wired Extreme today for a quote.
- You've been helped by a Wired Extreme technician.
Apr 16, 2010 | Sony PlayStation Portable (PSP) Console
Passanger side of the rad is cool driverside is hot fill hose is hot also exast poring out of driverside manifold back of motor could it just be the leak in the manifold
2 seperate problems . manifold gasket, and a blocked radiator , check for water in the oil,though i think it will be partial blockage of the radiator
Dec 29, 2009 | 1983 Dodge Pickup
DISHWASHER WILL NOT DRAIN COMPLETY
A small amount of water MAY remain because of backflow.
The pump cannot do well pumping air so the water that is in the upriser will come back in a bit.
Read up on dishwasher installation via Google and you should find that the drain lin is either raised up under the counter before going down to the connection OR an air vent protrudes through the sink to vent the line. Make sure your setup has one of these methods.
Dec 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
My Bosch wfd 1060 fails to drain complety. I have to drain it via the bottom front right drainage. Any advice on what the problem could be? Thanks a mil
Check and clean the filter, make sure the outlet hose is not blocked, if all else fails and you are sure the pump is getting a power supply, then replace the pump.
Please rate my solution.
Thanks.
Nov 09, 2009 | Washing Machines
Dishwashers Logo
162 people viewed this question
Top Admiral Dishwashers Experts
Paul Bade
Mike Carew
richie46
Are you an Admiral Dishwasher Expert? Answer questions, earn points and help others
