Question about Refrigerators
Whirlpool Refrigerator I have a 3 year old Whirlpool refer model ET1TTXKQ00, that makes a loud drumming noise from the lower, left, rear side. It lasts 2 to 3 seconds and is on an erratic schedule. It dosen't sound like a fan rubbing, but I havn't pulled it out to check it. Any help is appreciated.
    President:
  • 1,314 Answers
Sounds like your compressor fan all right pull it out and see could be any thing getting in the fan
Posted on May 14, 2008
Whirlpool duet front lading washer, GHW9150PW4
Could be drum bearings gone Quite a big job hence costly with around 3 hours labour plus parts, some models need half drum as the bearings are loaded in here,leak could be door boot seal at 7 yrs old not sure if worthwhile as its about the end of its working life.Good luck
Apr 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool electric dryer makes a loud grinding noise
Is there anything caught between the dryer drum and any housing. Can you hear it when the drum is turned by hand.
Jan 26, 2014 | Whirlpool Dryers
I have a kenmore side by side refrigerator freezer. It's about 15 years old. Recently the freezer has started making a loud humming noise. HELP
Good day,
The most common reason for noise is the fan motor in the freezer compartment.
Remove the screws from the rear panel in the freezer compartment and inspect the fan motor. Replacing it is a fairly easy nuts and bolts procedure. The motor should be available at most appliance parts houses.
kenmore is a trade name for Sears appliances. It was made by either Whirlpool or Frigidaire.
Sep 06, 2010 | Kenmore 57029 Side by Side Refrigerator
Our Hotpoint WF321 1200 spin is just 3 years old and now makes a very loud noise when in use - both for the washing and spin cycles. is the drum loose / off balance? any help appareciated
Remove lower rear cover of washer, remove drive belt, and from the front spin drum by hand, if it feels rough, or is rumbling, or noisy, then the main drum bearings are failing.
This is a major repair!!!.
Mar 13, 2010 | Hotpoint Washing Machines
Making loud humming noise
it is a relay chattering/buzzing on the control board located inside the lower left wall of the unit,it is inside a white plastic box,you need to unplug unit,then remove 2 screws holding the box,remove cover from box unplug the 3 wire harnesses and replace the board and reverse the disassembly procedure to put back together
Jan 08, 2010 | Whirlpool GS5SHAXN Side by Side...
Hi, my refrigerator is making a loud noise and it stops and starts about every 12 minutes. It is cooling fine. Can you help me? It is a side-by-side model that is only 4 years old. Thanks. This problem...
Good day,
Open the freezer door, and see if you can hear the fan motor, that is located behind the rear panel.
If it's the source of the noise, then you will have to remove the rear panel to access the fan motor.
If not, go to the back bottom of the machine, remove the back cover and see if the cooling fan motor that cools the condenser and compressor s working properly.
If it's alright, then it will probably be a problem with the compressor itself.
STOP !! The compressor has one year left on it's warranty.
Call your selling dealer for warranty service. This is an expensive repair and altering the machine can void the factory warranty.
Thank you for using FixYa
Jan 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool model ED5FHAXSLOO refrig 3 years old very noisy
If it is cooing fine, then the noise is probably your evaporator fan (the one inside your freezer). This can be cause by one of several things. The motor on this fan may be going bad, or, more likely, you may have a build up of ice around the blades that are touching the fan. This may be caused by a defrost circuit that has gone bad, or, the freezer may have been open alot lately and there is an excess of frost that hasn't melted away yet. If you can, manually defrost the freezer and see if it goes away. If it doesn't, it's probably the fan motor. If it does, and then comes back, it's probably the defrost circuit. Hope this helps!
Dec 06, 2009 | Whirlpool ED5FHEXMQ Side by Side...
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
Whirpool Refrigerator Making Loud Noise
I have the same problem. 3 years old fridge. Under warranty?
Aug 08, 2008 | Whirlpool GC5SHEXNS Side by Side...
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
