Question about Frigidaire Refrigerators
The refrigerator freezes everything, we have had the controls replaced with no luck.
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 12, 2010
Why does Our refrigerator keeps freezing everything? Even the food in the drawers are frozen. Why is that?
Check the cold control thermostat setting maybe you set it to max. put both controls on middle of whatever numbers you have on them and if its already on middle or at minimum setting still it freezing everything you need to replace to Cold Controller Thermostat
Aug 23, 2014 | Jenn-Air JCD2295HES Side by Side...
Refrigerator freezes everything in the refrigerator
Usually, there is a control knob/dial somewhere in the fridge. Did you try turning it to less power?
Nov 18, 2013 | Dometic RM2652 Refrigerator
My TRUE GDM49 refrigerator is freezing food...what do i check or replace?
HI,IF YOUR REFRIGE IS FREEZING IN THE REFRIGERATOR COMPARTMENT EVERYTHING ,CHECK THE AUTODAMPER OR AIRFLOW CONTROL FOR ICE BUILD UP ,NOT LETTING THE DAMPER TO CLOSE ONCE IS COOL ENOUGH IN THE REFRIG SIDE,MOST OF THE TIME WHEN REFRIGERATOR IS FREEZING TOO MUCH THE AUTODAPER IS BAD.GOOD LUCK..
Feb 21, 2011 | Refrigerators
My FR280 freezes everything. I suspect it lost refrigerant.
The refrigerant should never need "replacing" unless it has become contaninated by a leak on the low pressure side and formed acid-like compunds in the oil. I don't know the exact controls used in your unit so I can't give you a definite solution. Certain refrigerators with plate sensing controls can overcool with due to a low refrigerant condition. This would be evidenced by heavy ice build-up on a small area of the evaporator plate and none on the rest.
I do not feel this is the case with your unit. Does it ever shut off? I feel it is a control issue and most likely just needs a new thermostat.
If your unit had actually lost the refrigerant (it only started with 1.7 ounces) it would run and not cool and the compressor would likely trip off due to overheating.
If you are handy and are looking to do this repair yourself, let me know and I'll try to do more research. I you wish to have a servicer work on it, make usre the cost of repair will not be more than a new unit as is usually the case with a samll unit like this.
Good-luck, Subdriver
Apr 02, 2010 | Refrigerators
Why does my refrigerator freeze everything?
your thermostat is faulty and needs replacing
May 06, 2009 | Dometic RM2652 Refrigerator
Fresh food side freezing
the air damper is stuck open or tempature control is bad. look thru the vents(use a mirror) on the left rear(top side) of the fresh food compartment (right hand door) to see if the air damper is open/closed. i am sure it will be open since your freezing food in the ref section. if it is open ,watching with your mirror turn ref (fresh food) control off. the air dmper should close, if not damper could be stuck(ice build up,piece of foam,ect) if you can determine damper door is free, then best thing to do is replace controlassy.(120.00 or so) good luck
Nov 06, 2008 | Frigidaire FRS3R5EMB Side by Side...
EVERYTHING FREEZES!
Probably need to replace that temperature control. Also check damper. If manual, set to where less air is going to fridge.
Sep 24, 2017 | Amana ARB224RCW Bottom Freezer...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
