Question about Everex StepNote NC1500 Notebook
Can not turn on wireless LAN Help?!!!!! - Everex StepNote NC1500 Notebook
    Guru:
  • 377 Answers
Please see the manual if you don't have manual download it from this link
http://www.everex.com/support/nc1500/nc1500_downloads/everex_stepnote_nc1500_user_manual.pdf
Posted on Sep 07, 2010
Need isatap driver for vista
im assuming its a laptop computer
Turn the laptop over and remove the battery.
Remove the screws that are used to secure the memory/wireless LAN minicard cover with a Phillips-head screwdriver. Lift the edge of the cover to remove it.
Disconnect the antenna cables from the wireless LAN minicard with the needle-nosed pliers.
Locate the screws that are used to secure the wireless LAN minicard to the motherboard and remove them with the Phillips-head screwdriver.
Pull the wireless LAN minicard out by grabbing the card by the edges.
Reinsert the wireless LAN minicard and push down on the card to set it in place.
Tighten the screws to secure the card to the motherboard.
Replace the antenna cables with the needle-nosed pliers.
Replace the memory/wireless LAN minicard cover and secure it with the screws.
Replace the battery and then turn on the laptop. Windows Vista will load and reinstall the drivers for the ISATAP adapter.
hope this helps
Sep 22, 2012 | Asrock K8Upgrade-VM800 Motherboard
Wireless and Bluetooth not working running on ubuntu
Instructions
Close any open programs and files. Click "Start," "Run."
Enter "C:\DRIVERS\WIN\WLLANATH\SETUP.EXE" in the "Open:" box.
If your IBM T43 is running Windows Vista or 7, enter "C:\DRIVERS\WIN\WLLANATH\SETUP.EXE" in the "Start Search" box.
http://www.thinkwiki.org/wiki/How_to_setup_Bluetooth
Press the "Enter" key on your computer's keyboard. The Wireless LAN setup wizard will appear.
Follow the onscreen prompts to complete the Wireless LAN installation. You will be prompted when the process is complete.
5
Click "Start," "Turn Off Computer," then "Restart" to restart your computer when the Wireless LAN setup process is complete.
Tips & Warnings
If you haven't already downloaded the Wireless LAN utility to your T43 laptop, click on the "Wireless & Networking Accessories - ThinkPad T43/p" link in the Resources section. Then click on the "ThinkPad 802.11abg wireless Lan Mini PCI Adapter II" link to download the Wireless LAN utility.
Jun 07, 2012 | IBM ThinkPad T43 Notebook
Trying to fix router but when i put 192.168.0.1 in address bar !!!!! Unable to connect message always comes up So i cannot reset !!!! Having problem connecting to my wireless ipod blue ray @phone while at...
Are you using LAN? You can only access Administration if you reset the device through LAN (pressing reset button). You cannot access Admin config after reset through wireless... If your already using LAN, try turning your firewall off. And oh, your LAN should be plugged in to one of the LAN ports and not in the WAN port...
Jun 05, 2011 | D-Link DIR-615 Wireless Router
I lost my cd for setup ipls help me this is my serial number of my netgear 1um8977f03f04tnx
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point's DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network
Feb 21, 2011 | NetGear WGR614 Wireless Router
Were do i turn on my wireless connection on my laptop?
INSTALLING THE WIRELESS LAN DEVICE DRIVER
Please follow the procedures below for installing the Mini PCI Adapter driver:
Installing Wireless LAN driver for Windows XP
1. Click the Start button and then click Run. The Run dialog box appears.
2. Click Browse button and specify the directory as "E:\Drivers\Winxp\Wireless LAN\setup.exe"
3. Click "OK" to implement the setup program to install this driver.
4. Click "Next" twice to continue the installation.
INSTALLING THE LAN DEVICE DRIVER
• Wireless LAN Access When LED turns on indicates that the wireless LAN module is activated. When LED lights off, it indicates that the function is disabled
MUST BE A SOFTWARE ACTIVATED SWITCH
Jan 21, 2011 | Everex StepNote NC1500 Notebook
The bluetooth turns on using FN + F11 it should turn the wireless too but doesn't MSI U100
As per the manual the FN and F11 keys turn on both Bluetooth and Wireless so you need to try it will turn bluetooth and then it will turn on wireless, you can check them by LEDS
Press and hold the Fn button, and then press the F11 button
repeatedly to enable or disable the Wireless LAN or Bluetooth function
recurrently.
Wireless LAN and Bluetooth:
�� Wireless LAN LED indicator glows green when Wireless LAN function is
enabled.
�� Bluetooth LED indicator glows blue when Bluetooth function is enabled.
�� Both LED indicators glow green and blue at the same time when both
functions are enabled.
�� Both LED indicators go out when both functions are disabled.
�� Note: For flight safety consideration, make sure these two LED indicators
go out when you are in flight.
Let me know if you are able to turn the wireless on
Also i will suggest you check in device manager that you wireless adapter is enabled
Regards
Dec 02, 2009 | MSI U100-001US Netbook
Where is button to turn on wireless internet connection
see the operating instruction manual here :
http://dl.owneriq.net/d/d94ab07b-788b-41ca-8def-00135155738c.pdf
or read below :
For instructions on settings for wireless LAN and cautions during use, select [start]-
[Reference Manual], and refer to "Wireless LAN".
Before using a wireless LAN, turn the wireless LAN on using the following method (at
the time of purchase, the wireless LAN is set to [Off]).
Double-click on the taskbar.
2 Select your wireless LAN adaptor and select [General].
3 Select [On] for [Switch radio].
4 Select [OK].
The icon will turn to or ��
Oct 04, 2009 | Panasonic Toughbook T2 Notebook
I own a HP DV9000 my wireless quit working
Check the Device Manager to see if the Wireless LAN device is working and enabled. If not reinstall the Wireless LAN driver.
If the Wireless LAN is OK and enabled then sometimes when you bootup the Wireless LAN card doesn't get an IP address from the wireless router. This usually has a red X on the wireless connection icon and sometime you get an error message "Limited or no connection".
To get the router to issue the wireless LAN card with a new IP address, righr click on the Wireless icon and click on Repair.
You can also power down the router wait 15secs and power up the router again then reboot the computer.
If it still doesn't work you could have a faulty wireless card, see it your friendly computer shop can test it for you.
Jun 30, 2009 | HP Pavilion dv9000z Notebook
My Toshiba Satellite PSL30A-00100E wont pick up wireless LAN
there is a switch on the front of the laptop on (just under the mouse) on its "face", it just says on off
Nov 28, 2008 | Toshiba Satellite L25-S119 Notebook
Wireless network undetected and problem with wireless lan
first check for whether the wireless switch on laptop is turned on or not u have to keep it turned on .further install the drivers for wireless lan
Nov 21, 2008 | Toshiba Satellite A100-S8111TD Notebook
Everex StepNote NC1500 Notebook Logo
37 people viewed this question
Top Everex Computers & Internet Experts
k24674
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
