Question about Canon GL2 Mini DV Digital Camcorder
MANUEL ZAMS@CHARTER.NET
REPAIR AUDIO BOARD
ADJUST HEAD TAPE PATH
GENERAL CLEAN & CHECK
HOW MUCH SUPPOST COST THIS
  • ZAMS6262 May 14, 2008
    WHEN THE TECHNICAIN SAID REAPIR AUDIO BOARD
    WHAT DOES MEAN CAHNGE FO R NEW BOARD OR ONLY REPAIR
    Genius:
  • 2,785 Answers
Generally it is cost effective if you repair the board,
if the cost of repair is almost same as the new board then you should go for new board
Posted on May 14, 2008
    Sergeant:
    Champion:
  • 230 Answers
It will cost very less only i think wait i will tell you
  • 3 more comments
  • balachander megavarnam
    balachander megavarnam May 14, 2008
    tell the model number of your camcorder
    better you try repair the same audio board itself.........if it is new one then you can apply for warranty
    because if you repair the board ........it may void the warranty
    for Sony, Panasonic and Canon the audio board is usually costs around
    $195..........so it is better to repair the old board itself
    if you have $195 you can go with the new board itself..........if you have then you can go with repairing the old one
I have an old Sony CCD TR55E Handycam, I bought from new. Now I want to transfer my tapes to DVD, and seem to have lost sound output playing tapes to TV/Recorder. Tried running tape cleaner, no succes
What is your signal path? The question you need to answer is, "Where are you losing the audio?" Are you losing it between the tape and the playback head, or are you losing it in the cable, or are you losing it at the TV/Recorder?
Does the camera have an audio out into which you can plug ear buds to test the audio from the camera playback?
Nov 28, 2014 | Sony Cameras
Tip
How to clean a VCR tape machine.
You just rented a tape and your VCR will not track properly or you tried to record a tape and it would not play back. You have a dirty machine.
Remove the power. Remove the top cabinet by removing all the screws on the back and probably a few on the bottom. Once the top is off look to see where the video tape comes into the machine. Directly ahead of the input is the video drum assembly. It should be about 2 or 3 inches in diameter and be directly in front of the tape slot. It is very fragile and should never have any cleaning device moved up and down on it.
Once you locate the video drum you should saturate a cotton swab with a 100% alcohol solution and while turning the drum slowly with the swab pressed against the video drum you should be able to clean the heads.
The heads are very small and very fragile. Any vertical movement will break them. After cleaning the video heads move to the erase head, CTL head and audio head.
The erase head is located to the left of the tape path entry to the video drum assembly. The CTL head is located with the audio head on the right side of the tape exit from the video drum assembly. Using a swab saturated with alcohol clean all these heads.
You should also clean the tape path and load mechanism ( the tracks that the tape guides slide on). Clean the pinch roller and capstan.
All cleaning supplies such as 100 percent alcohol and lint free cleaning swabs are available at http://www.mcminc.com .
This should complete the cleaning of your VCR. If all went well the unit should now work.
Thanks for using FixYa and for the great rating.
hardrocko
on Sep 12, 2010 | Televison & Video
Cannot get voice to my computer with speakers
http://www.hardwaresecrets.com/article/How-On-Board-Audio-Works/28
Nov 09, 2013 | charter.net
Heads and tape path need cleaning
if you don't know what u are doing u shouldn't mess with video head. U can easily damage the head. If cleaning tape does not work have tech do it. Should be relatively cheap.
Apr 22, 2009 | Televison & Video
Go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
Nov 30, 2008 | GoVideo VR4940 DVD Player/VCR
Audio drops out every few sec.(3 sec.) then ok for about 5 sec. it seams as i shake camcorder lightly side to sides the intervals changes too +1 -1. i have red here problem as tape misalignment which is...
Thats a possibility. I don't know why it costs so much since all you have to to is take a small screw driver and adjust the audio head. You might try cleaning it with a DV tape cleaner and see if that makes a difference. It's cheaper than the repair shop.
Jun 24, 2008 | Sony DCR-VX2000 Mini DV Digital Camcorder
VCR acting strange with audio and playing
It sounds like the audio control head is at fault.
If all prerecorded tapes (movies) play with audio level jumping up and down, is is likely that the audio head is dirty. The audio head in the VCR looks very similar to a head of an old audio cassette player.
First, try to clean the audio head by running a VHS head cleanning tape. The cleanning tape will usually clean the path of all tape mechanisms..
Good Luck
Feb 25, 2008 | Panasonic PV-V4523S VHS VCR
No sound on tape
hi , many faults for that 1- have you tried to play an old tape with sound to check that the video plays sound ?? if you have the sound of a previous tape then move to 2- from where you are recording if you are recording from tv rf channels then move to 3 or if you are recording from dve chek the audio connection that are coming from dvd to video and change it 3- the remaining last fault is you have a dirty audio head needs cleaning and if you don't know how to do so go to qualified person and if you are familiour with that open case and clean and if no refer to 5 5- the audio head it is a chrome cube with a black two thins lines in the right of the mechanism near the pinch roller rounded thing that draws the tape to move get a clean cloth and spread alchohol on it and rub the rectangle cube audio head up and down ovewr the two thin black things inside it please don't forget to do excelent rate cause i here to help you regards
May 06, 2007 | Aiwa VX-C131 13 in. Combo
Sony Handycam Model CCD-V801 does NOt Play
Hai, Check with previous recorded tape, If it is not playing. Clean video head with head cleaning cassatte. Before that please check is it going to VTR mode & also is it takes play indication. Then check with pre-recorded cassatte. thank you best of luck udupi
Mar 13, 2007 | Sony Handycam CCD-TRV81 Camcorder
Canon GL2 Mini DV Digital Camcorder Logo
76 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
