Question about Wagner Power Products 0154842 Medium Spray Gun Filter, 50 Mesh
My Wagner 5.4 gph SprayFast sprayer won't spray. It just huzzes/hums when I pull the trigger. The pump isn't turning over. I thought I've been diligent in cleaning it when I was finished. Anything I can do with it to get it going again?
  • 1,040 Answers
You may have a dirty tip. Try replacing it with a new one. Also check to make sure that you have it assembled correctly.
Posted on Sep 08, 2010
What cain of oil a cant uuse for wagner 1250 hp
Your Wagner 1250 is a diaphragm airless sprayer, which uses hydraulic oil to push the diaphragm, so the oil must be hydraulic quality as it gets quite hot; don't use any other type. The Wagner part number for their quart size is 0088009
Jun 15, 2015 | Wagner SprayTech Wagner Airless Paint...
Does a Wagner Paint Crew sprayer take lubricant?
The Wagner Paint Crew airless sprayer does not require oil for its operation like full professional sprayers. The piston is off-set from the pump chamber with the inlet and outlet valves opposite each other, however you need to protect the parts from corrosion between use and Wagner recommend running some light oil through it after cleaning. If you will be using it in a day or so for water based paint, you could run a 10% solution of their EasyGlide through it.
Sep 30, 2014 | Wagner Spray Tech Wagner Paint Crew 2750...
Spray gun problems
You basically have what is called a "cupgun" and there are a few reasons for this and it should be pretty simple to fix I want to stress that anytime you spray the paint no matter what latex-oil needs to be thinned with the compatible solvent water for latex paint thinner for oil/Alkyd by about 10% - 18% that could be the problem if you have latex in your gun but probably it has to do with the "needle seat" in the back of the gun there should be a knob to adjust the needle turn your gun on pull the trigger and turn knob till paint comes out if that wont work you may have debris in your paint that has clogged the stem pour all the paint out clean gun completely pour paint threw a strainer cone or strainer bag and be sure to thin it...
Sep 01, 2014 | Wagner Paint Sprayer. Flexio 570 HVLP...
Shoots drips
Most airless spray guns spit a bit when you pull or release the trigger because the paint between the spray tip and the paint valve is under pressure but not enough to atomise the paint. If you increase the pressure you may reduce the spit to a point when you don't notice it. A blocked filter could slow the paint getting through to the tip cause lower pressure.
Jan 03, 2014 | Wagner SprayTech Wagner Airless Paint...
Old Wangner Cap Sprayer & Compressor
The Wagner Capspray 9000 HVLP is about 20 years old, but you should be able to find parts, at least for the HVLP gun. The manual for the turbine is #0276989. If you are in the US try Scott at American Airless Wagner Titan Graco Paint Sprayers or in Europe try us at:
Home Lion Industries
Jul 28, 2013 | Wagner Spray Tech Cap Spray Paint Sprayer,...
I have a wagner hvlp control sprayer and it will not spray out the paint from nozzle? why? it is not clogged???
On my Wagoner sprayer, it is possible to turn the nozzle 180 degrees to clear it. Does yours have this feature? I thought my sprayer was faulty (being very cool myself, I didn't read the instructions) maybe due to non use or age as it has sat on the shelf for two years since last use. I bran out and bought another one. After about 10 minutes of use, the new one stopped. I cleaned and cleared and still had no luck. I bought pipe cleaner and little brushes ... you wouldn't believe all the trouble I went to to make sure the nozzle was clear. I was convinced the trouble was with the motor and not the nozzle. Then, I read the instructions ... they said to turn my nozzle 180 degrees and pull the trigger - IT WORKED!)
If yours will not spray, there is a motor trouble or there is a clog somewhere between where the paint is and the nozzle. Believe this and believe that the sprayer was made to work and it was not made to not work and you will discover your trouble.
Thanks for your question ... I hope I have provided some insight for you.
Jun 20, 2011 | Garden
I have a wagner power painter 355E and the directions said to put oil in the 2 holes in the gun. Where are the 2 holes?
Where the raised tips of the tubing goes into the gun,
directions state ,"Apply a light coat of oil."Tip sprayer up side down (so handle is sticking up) and the underside where the two holes where the ditting dual hose go in there: This is where you put a small amount of oil into both holes and trigger the sprayer briefly
May 08, 2011 | Wagner Power Products 0154842 Medium Spray...
I purchased the Wagner power tex and loved it, recently it doesn?t spray with the ease as it did when I bought, I haven?t used it a lot only to do fill in?s, seems like it only releases the texture once...
Your sprayer is self powered? you don't use a separate compressor? I have one with a compressor and it has to be taken apart " the gun" everytime or the trigger becomes stiff. If it's self powered, I would say your mixture is too stiff and water and it should be fine..If not and if it's self powered, then your motor may not work properly.
Mar 17, 2010 | Wagner Power Tex Texture Sprayer #0520000
Wagner Power Products 0154842 Medium Spray Gun Filter, 50 Mesh  Logo
680 people viewed this question
Top Wagner Air Tools & Compressors Experts
JOHN LAPIER
ray gallant
 Andy
Andy
Level 1 Expert
Are you a Wagner Air Tool and Compressor Expert? Answer questions, earn points and help others
