Question about Sentry Fireproof Safe
Sentry H4100 file safe
I just purchased this safe I put my paycheck in now it won't open I tried both keys The key seems to turn but it won't unlock  Help
  • 2 more comments
  • Anonymous Sep 05, 2008
    same the key turns left and right,but safe will not open-gary
  • MsOD Feb 22, 2009
    I have the same exact problem but my daughter's seizure meds are in it. I have tried almost everything.
  • Anonymous Mar 13, 2014
    We have tried opening our safe using our key to no avail. How do we get into it? The keypad is no use/batteries dead.
  • Anonymous Mar 22, 2014
    Need New Keys
There is a lock and there is a latch.
You can latch the safe without locking it and unlocking it does not unlatch it.
After you unlock it, then you must press up on the spring loaded latch while (this important) pressing down on the cover to releast the pressure on the latch hook, allowing it to move out of the way. After the latching hook is out of the way, you can release the pressure on the lid and it will open. You can't see the latch hook as it drops down from the lid, into the front wall of the safe where it engages a post, but perhaps you can imagine what it looks like.
Mine will not unlatch, even though it is unlocked, unless I press down on the lid to give it clearance first. There is quite a bit of spring in the plastic that this safe is constructed out of. It works against you when you try to open it and close it.
I can take digital photos of the mechanism if this description does not help.
Another Gary
Posted on Sep 10, 2008
Have key and code...safe will not open
Sentry Safe not unlocking - YouTube
? 0:36
https://www.youtube.com/watch?v=4mbtSUAoS6w
May 8, 2013 - Uploaded by 1diazsantana1
When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
Opening a Sentry Safe with a Rubber Mallet, some WD-40 ...
idoneitmyself.com/.../opening-a-sentry-safe-with-a-rubber-mallet-some-...
May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
Jan 05, 2016 | Sentry Safe Fire-Safe .8 Cubic Ft....
How do I open sentry H4100 file safe
Proceed to watch this video link that I added. It will guide you on how to open your stuck file safe. HowTo Open Stuck Sentry Safe H4100 Others
Oct 19, 2014 | Sentry Safe Products Sentry Safe H4100...
I lost a key of my safe
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Homelb_icon1.png/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. They key ordering screen is: www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
For Small Chests or Files: (Model numbers will begin with 0500, 1100, 1110, 1150, 1160, 1170, 1710, 1900, 1950, 1970, 1200, 1210, 1250, 2100, 2180, 2275, 2460, 6000, 6720, 7150, A3750, A5781, A5865, F2300, F3300, H2100, H2300, H3100, H2300, H3300, H4100, H4300, HD2100, HD4100, KDS-1, KS2100, KS4100, U2101, WD2, WD4, ESB-3, etc... ): A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock (right around the hole where the key goes in at).
For Personal, Home and Home/Office Safes:(Model numbers will begin with: S0 (S0310, S0400, S0407, S0408, S0409, S0410), S3 (S3300, S3310, S3401, S3410, S3417, S3421, S3460, S3467, S3470, S3710, S3807, S3870, S3877, S3910), S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, CS, CSW (CSW3460), DA (DA3831, DA3930), DS (DS3410, DS3431, DSW5781), KSW, MS, MSW, OA (OA3810, OA3821, OA5848), OS (OS0407, OS0410, OS0810, OS3407, OS3421, OS3470), SC, and X (X031, X075, X105, X125)): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges. Keys Sentry Safe Replacement Keys Keys Sentry Safe Replacement Keys
Apr 07, 2014 | Sentry Fireproof Safe
Can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Apr 18, 2009 | Sentry Fireproof Safe
Key wont unlock safe
Turn the key back and forth and hit on the top of it with you fist.It should open.
Mar 30, 2009 | Sentry Fireproof Safe
Factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Nov 23, 2008 | Sentry Fireproof Safe
My sentry safe
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
Feb 06, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
1,766 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
