Question about Sceptre X9G-NagaIV 19" LCD Monitor
How do you disassemble the case to repair light?
  • 11,361 Answers
You remove all the screws and the stand, then use a thin flat blade screw driver to crack open the case starting at the bottom edge of the monitor first and work your way around, it is kind of hard to explain in words, just be real careful on the switch assembly in the front bezel.
You can also look a YOUTUBE on how to disassemble LCD monitors.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Sep 07, 2010
2008 Hyundai Accent 2 door hatchback- passenger door is stuck and won't open from either inside or outside. What can I do without paying a lot?
Unfortunately not much. If the door will not open from inside/outside, it will most likely be a lock issue. In most cases, the door will need to be disassembled for access to the interior components. The door is not designed to be disassembled while closed. If put into the wrong hands for disassembly while the door is closed, you most likely will end up with interior panel damage which could cost more to repair/replace than having a pro complete the repair fist hand.
Mar 07, 2016 | 2008 Hyundai Accent
I plug iron red light stays lit but sole plate dont get hot
The connection to the resistance might be burned out. disassemble carully, might need soldering.
If you disassemble and don't have experience repairing an iron, take photos for each step. See some videos about iron repairing
Iron Disassembly Process
Iron Repair No Power or Short in cord wire Rowenta Master
How to repair broken iron
Iron Repairing sajid salman flv
Oct 26, 2015 | Irons
Need to disassemble to replace fan and light buttons
You can't. Microwave ovens do not have consumer repair options. The case is held on by special screws only the technicians can undo due to the catastrophic damage that microwave energy can do to the human body. Blind in 25 seconds sound like fun? How about poisoned to death in 90 days by the heavy metal compound in the magnetron core?
Oct 04, 2015 | Microwave Ovens
Burnt smell on oster blender
If you have eelctric knowledge, disassemble the case and look for some corroded contact or cable.
You can follow some of these youtube tutorials or look for additional info by doing a Google search using terms
Youtube disassemble blender
iFixit Blendtec Total Blender Disassembly
How to open and repair Braun Hand Blender Part1
KitchenAid Blender Coupler Repair KSB5 Model
OSTER Blender Repair How to fix an broken driver
If you are not familiar with disassembling a blender but you feel you have the knowledge to do it, take a photo of each step so when you have repaired the problem, you should have no problem to reassemble it again
Sep 04, 2013 | Blenders
Disassembly of the Samsung i897?? I'm looking for a guide to disassemble this model. Samsung Captivate. Thanks
Its a case of trial and error i'm affraid. There are no manuals or video tutorials out there at the moment which can guide you.
Someone at a phone repair store maybe able to help.
Regards.
Dec 15, 2010 | Samsung Captivate i897 Cell Phone -...
I have a problem on fan can you solve? It's a noisy fan
Most of the problems with cooling fans in equipment is due to loss of lubrication. What anybody would do in this case is take out the cover of the receiver and replace the noisy fan, or, in case you are able to do so, repair the fan.
In fans with ball bearings, you can do nothing but disasembling the fan and replace the tiny BB, in fans with sleeves bearings, you may disassemble it, clean it well, and put some oil or light grease in it before reasembling it.
Dec 09, 2010 | Audio Players & Recorders
2002 yukon front end wont engage
2002 GMC Yukon
2002 GMC Yukon
2004 TRANSMISSION Transfer Case - NVG 149-NP (One Speed Automatic) - SUV
TRANSFER CASE NO FRONT DRIVE
Transfer Case No Front Drive
Cause
Correction
DEFINITION: The transfer case is not delivering engine torque to the front propeller shaft.
Review the Symptoms - Transfer Case and perform the necessary inspections.
Viscous coupling faulty 1. Inspect the transfer case fluid for being black. If the fluid is
black, it is most likely caused by a viscous coupling failure.
2. Test for a faulty viscous coupling. Refer to Transfer Case
Description and Operation.
3. Disassemble the transfer case. Refer to Transfer Case
Disassemble in Transfer Case - NVG 149-NP3 Unit Repair.
4. Inspect the viscous coupling for a bulged cover. Refer to
Cleaning and Inspection in Transfer Case - NVG 149-NP3 Unit
Repair.
5. Replace the viscous coupling if it is faulty. Refer to Transfer
Case Assemble in Transfer Case - NVG 149-NP3 Unit Repair.
Planetary carrier faulty 1. Disassemble the transfer case. Refer to Transfer Case
2. Inspect for faulty planetary carrier components. Refer to
Repair.
3. Replace any faulty planetary carrier components. Refer to
Transfer Case Assemble in Transfer Case - NVG 149-NP3 Unit
Repair.
Oct 19, 2010 | GMC Yukon Cars & Trucks
Number indicator light only half working, how do i fix?
you need to replace the channel indicator unit. It is an involved process where you must disassemble the radio. lots of small screws then lots of unsoldering and soldering.
Mar 05, 2010 | Cobra 29 LTD CB Radio
How do i remove a transmission out of my grandam
Buy a Haynes repair manual it is an extensive job requiring the disassembly of the front suspension and in some cases the disassembling of the sub frame to drop the tranny down I wouldn't recommend the undertaking to the average layman mechanic.
Sep 18, 2009 | 1999 Pontiac Grand Am GT
Sceptre X9G-NagaIV 19" LCD Monitor Logo
319 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
