Question about Eddie Bauer Baby Gear
I have the Eddie Bauer Classic Wood Swing that wont swing. The music still plays but the swing function will not turn on. I replaced the batteries just in case and that still did not help. What could be the problem? Is there a safety feature on this swing that could cause the swing to not turn on?
Take apart the side with the on and off switches take apart the swing arm, remove the plastic cover over the motor look at the
blue wire from motor thru the plastic all the way to the contrl board prob broken where it goes thru plastic from motor looks like it happens alot
Posted on Jan 04, 2011
I bought an Eddie Bauer infant swing 2nd hand and it won't swing. I put new batteries in but still it won't do what its suppose to. Any ideas?
Does it play the tunes? If not, verify that the batteries are installed correctly. If that is not the problem, read on:
I don't know about your particular infant swing, but those I have seen use a vibrating motor to drive the swing. This a small electric motor with an intentionally out of balance weight on the shaft. When it spins, the whole assembly shakes. The drawbacks to this design are that the weight may come loose so the motor spins without turning the weight, the wires to the motor may break off from the vibration, or the motor bearings may go bad from the heavy wear.
You would need to open the housing to see what the problem is. A broken wire is usually easy to repair if you are good with soldering. A loose setscrew on the weight can be secured with a thread-locking compound. A worn motor bearing, on the other hand, cannot be economically repaired. (The shaft of a worn-out motor will have a lot of side play - if it's worn to the point of failure, the armature inside the motor may drag on the field magnet and be hard to turn, or the motor brushes will not make proper contact with the commutator.) These motors are generally very common varieties and are available from Jameco Electronics or Radio Shack. For example, Vibrating Motor 3 Volt DC 75 mA is $3.25 plus tax and shipping.
Nov 30, 2014 | Eddie Bauer Baby Gear
How do I change batteries on Eddie Bauer "Gentle VIbrations" baby swing?
i believe it uses 4 c batterries there is a compartment at the bottom and it screwed in with a philips screw. you need a philips screw driver number 2
Aug 29, 2014 | Baby Gear
Cosco swing and play music plays but does not swing
Take it back they will replace it for you for up to 2 years.
Apr 25, 2014 | Cosco Juvenile Cosco Sway n Play Swing...
The bassinet wont rock?
hmm all the bassinets by eddie bauer as far as i no do go by them selves, but theres a lot of recals on them!
Jun 26, 2009 | Eddie Bauer Musical Rocking Bassinet...
The safey belt on my Eddie Bauer swing is broken.
often with a trip to a hardware store you should be able to fine something you could replace it with, and probably it will be stronger than the original
Jun 15, 2009 | Toys
I have a rainforest swing and everything on it
You can order the broken part and replace it. Call Fisher-price customer service and they will help you with that.
Apr 09, 2009 | Toys
Eddie Bauer Classic Wooden Swing
where did you purchase the swing?
Sep 28, 2008 | Toys
Baby Gear Logo
917 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
woodzowl307
ray gallant
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
