When you add toner to the machine, they tell you to clean the charge wire by running a green lever back and forth across the corona assy.
If you do not get it back into home position, it makes a shadow, resulting in a black line.
It happens all the time.
There is a green lever inside on the process unit(the one where you put the toner onto). Just move this lever from right to left and back and see that it clicks when you put it back to home position and the continuous line from top to bottom should vanish. If not, take the process unit out of the printer and do the above procedure a couple of times. Actually once I also found a small cockroach burnt up inside there(called the main charger assy).
I just replaced a new toner but could not print. The start button is not responding even when I try...
(More)
I just replaced a new toner but could not print. The start button is not responding even when I try to print the status page. What could be the cause.
The first green light and the bottom red light are blinking simultaneously. The second green light...
(More)
The first green light and the bottom red light are blinking simultaneously. The second green light remains lit. The printer won't print. What do I need to do?
was printing, stopped, then 4th light from the top turned red. Has restarted it..still not...
(More)
was printing, stopped, then 4th light from the top turned red. Has restarted it..still not printing!!!
I have justset up and installed this printer onto my laptop. However since turning it on and setting...
(More)
I have justset up and installed this printer onto my laptop. However since turning it on and setting it up, the 3rd light from the top has stayed red. I think it is the paper tray light (but not sure as I dont have a manual!) The printer has not done any printing yet, so it cant be a paper jam? Does anybody know how to sort this out?? Many Thanks
