Question about Kenmore 17252 Free-standing Dishwasher
Water standing in tub,already removed cleaned screens,also drain hose is not plugged,can feel spindle spinning on pump out motor.Would impeller be shot??....thanks
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 10, 2010
When it hits the final spin it makes a cruching noise and will not drain
Sounds like you have a bad drain pump. Usually the impeller will break off the pump shaft and spin freely inside the pump causing the noise. You will need to remove the pump and feel inside and see if the impeller is broken. Be sure to have a shop vac handy to drain the water from the unit before removing hoses. If its a frontload remember there is alot of standing water in between the tubs. Good Luck.
_MJ_
Dec 15, 2010 | Frigidaire Washing Machines
Water not draining even after clean
The dishwasher has an outlet pump in line with the outlet hose. This pump must work in order for the washer to drain. The pump can be tested by unpluging it and removing the 2 hose clamps. Connect the pump to the mains for a few seconds and it should spin the impeler. The impeler must rotate a a speed and must not be obstructed in any way. If this does not spin the outlet motor it should be replaced.
Jan 20, 2010 | AEG 24 in. Favorit 40650 Free-Standing...
Frigidaire Front Loader won't drain after cleaning out tube?
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jul 14, 2009 | Frigidaire FTF530FS Front Load Washer
Maytag dishwasher that won't drain when finished
HI, usually, if the dishwasher dose not drain properly, it will be the fault of a defective or, malfunctioning pump. i will list several problem areas to check. Inspect each area properly and, replace any component that is faulty or fouled.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jun 22, 2009 | Maytag MDB6000 Dishwasher
Washing machine wont wash screen says test.
Its a draining problem.the drain pump is either got blocked so needs cleaning or the drain pump is faulty and needs replacement. --------------------------- If your washer won't drain, check these:
Jun 11, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Will not drain, already cleaned coins and debris out.
May 06, 2009 | Washing Machines
There is standing water in the bottom of my dishwasher.
Check the following.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Mar 19, 2009 | Whirlpool DU930PWS Built-in Dishwasher
Asko D3100 dishwasher wont drain completely
I think I see the problem based on "futureloginn"'s highly rated solution. You have a dishwasher. You need to stop washing clothes in it.
Oct 27, 2008 | Asko 24 in. D3112 Free-Standing Dishwasher
Miele washing machine wont drain
hi friend,
hoses
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 15, 2008 | Miele W2240 Front Load Washer
Drain and spin cycle
Okay...the problem may be that you have something caught in the drain pump preventing the impeller from turning. Or, the pump itself may have stopped working. If you experience a problem where the washer does not drain or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Please read ALL instruction before attempting.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the screws at the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located under the wash tub (it is the only pump this washer has).
4. The pump can be removed and the housing taken apart to clean out the impeller trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and place them under the pump. Remove one of the drain lines and allow water to drain. If the tub is still standing in water (as you stated) bail as much from the tub before removing the drain lines from the pump (if you are using the towel method for collecting water).
6. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the housing cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select a wash cycle. Allow the tub to begin filling and check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping.
10. If there are no leaks, you can stop the wash cycle at any time and select a drain cycle. If the drain pump works normal, reinstall panel and tighten screws.
11. If your pump still does not run, more than likely, the impeller motor is damaged and the entire pump must be replaced. The motors typically are the part that fails on this pump. Follow the previously mentioned procedures for removing water from the wash tub.
NOTES:
a. Your pump is item #916709 at repairclinic.com. Or part number 134051100 at searspartsdirect.com. Just type in your model number in the search menu and a parts index with pricing is made available to you. the pump is listed as an "askoll pump" under the "Tub" header at the Sears website. HINT: Sears has it a little bit cheaper.
b. It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
I hope this information is helpful. If you have any questions/concerns, please post back with your comments. Good Luck.
Feb 27, 2008 | Washing Machines
Kenmore 17252 Free-standing Dishwasher Logo
125 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
