Question about Craftsman 675 Series 190cc 22" Briggs Stratton Rear Bag Front Propelled Lawn Mower ()
Bag keeps falling off is there a trick to stop it from happening
WHEN JET VAC HAS FINISHED CLEANING AND STOP THE LEAVES ETC FALL OUT OFF THE BOTTOM
The bag is supported by the jet of water shooting into it. When the pump stops, the jet stops and the bag should fall over sideways, retaining the leaves. I'm curious, Letro was bought out by Pentair 10+ years ago and the Jet Vac was discontinued. Also the description says that this cleaner runs without a booster pump. Every Jet Vac I have ever met runs with a booster pump. Are you sure the installation is correct?
Nov 14, 2014 | RTO Letro Jet Vac Automatic Pool Cleaner...
Cougar model 26CSV8
probably have to find something that will work in it's place.... small engine shop would be your best place to start
Nov 04, 2013 | Garden
Kirby heritage 2 wont stand upright keeps falling over
Is your bag too full? the added weight will tip over your vacuum, especially if you're using the attachment hose. Check the bag. If it's over the "indicator line", then change it. See if that helps.
Feb 11, 2013 | Kirby Heritage II Vacuum
Shredder keeps stopping and the bag is not full
there are three switches on most shredders that can cause them to stop.
1) a jam
2) door ajar
3) bag full
If you can rule out a jam, and the door ajar light goes on when the door is open and off when its closed, and the shredder has not been undergoing very heavy use (they will overheat and shut off, then be fine in 15 min or so)
then its a safe bet to say that it has to do with the switch that tells the shredder that the bag is full (when you take out the bag you can see a metal flap hanging down at the back of the top opening)
the way that the shreddings fall can often trip the swtich that tells the shredder that the bag is full, shake the bag a bit so the paper resettles that often fixes it.
Nov 08, 2011 | Fellowes Office Equipment & Supplies
Using hoover, stopped working. Bag very full so changed. Hoover seems very hot. Will not work. Checked fuse
Give the vacuum time to coold\ down, then try again. If it still doesn't work, take it to a repair shop to be checked.
When a vacuum is used for long after the bag is full, the motor can overheat to the extent that the motor burns out. This is one of the benefits of having a vacuum that shuts off when the bag is full.
You should also check the hose for clogs. Disconnect at both ends and drop a coin in one end. If it fails to fall through, there's a clog that needs removed. This is likely to happen at the canister end when the bag gets too full.
Apr 04, 2011 | Miele Cat & Dog 326i Bagged Canister...
The bags keep falling off
The nozzle pictured upon which the bag holder mechanism broke on my machine. Took it to Oreck dealership twice and he kept replacing the bag holder, but mostly trying to sell me a new vac.
Problem was, the bag holder mechanism itself was no longer attaching to the exhaust port because a major portion of the attachment device simply went missing. Notice that in the pics I post there is obviously something missing. A product failure. We don't abuse our stuff.
Solution? I drilled two small holes on either side of the bag holder mechanism and then fed a very small zip tip around the mechanism and around the plastic cloth bag holder support so it can no longer disconnect. Key to this is to feed the zip tie from behind the plastic cloth bag holder support so that the fat part of the zip tie does not interfere with the connection of the bag support to the bag holder.
Here's a pic of what I did.
Feb 15, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Coffee doesn't fall in bag (bunnomatic G1 coffee grinder)
keep clicking the De-chaf lever on the right. This tamps down all the loose grounds. Static is common with coffee due to the low humidity of the grounds (even here in Hawaii) try attaching a small metal chain to the grinder case with a used coffee clip on the end of the chain to attach to the empty bag. This will help it 'ground' out the static to the case.
Feb 10, 2010 | Bunn -o-matic G1 (1 lb. Bulk Grinder)
Shaved hairs fall out of shaver head
IT'S A GOOD THING THAT THE HAIR COMES OUT ITS STOPS THE CLIPPERS FROM JAMING. USE A GARBAGE BAG AND POKE A HOLE BIG ENOUGH FOR YOUR HEAD. PUT THE GARBAGE BAG OVER YOUR SHOULDERS AND TRIM AWAY. THAT WILL HELP IT FROM GETTING OVER YOUR CLOTHES. IF YOU HAVE A GARAGE PUT A MIRROR IN THERE AND YOU CAN SWEEP UP THE HAIR OFF THE FLOOR EASIER THAN IN THE HOUSE.
Dec 26, 2008 | Braun 360° Complete 8985 Electric Shaver
Dust collector
dust collectors usually work off the motor via a fan. Either the fan is broken or the bag is blocked up.If the bag is too dirty inside you don't get any airflow through the bag which can stop it collecting. A good wash should do the trick
Aug 29, 2008 | Porter Cable 3" x 21" Electronic Variable...
Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
862 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
