Question about Acer Aspire 4720 Notebook
My camera lens got stuck . it is not going inside, i tried switcinh on and off.didnt working.. ples help
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 146 Answers
Try this, remove batteries, and gently twist the lens in anticlick wise direction while holding the camera. Remember you dont wanna break it, do it gently. when u feel there is some movement, inset the battary and try to switch it on, it shud get fold back inside..
Cheers!
Posted on Sep 07, 2010
Why i cant turn my kodak easyshare one s143 on? What can i do!? i really dont know!
Does the lens come out? Could be the lens motor/transmission is stuck. If the lens is stuck the camera won't start. Except maybe in Favorites. Repair is, if possible, very expensive.
Jul 14, 2014 | Cameras
The lens of my samsung es55 is stuck inside, i have tried moving it to make it centered but it didnt work. it comes out a tiny bit then there is one beep and it goes back inside. i saw a lens for this...
It is unlikely that the lens itself is causing this problem. It is more likely to be a problem with the lens gearing which may be misaligned or obstructed by a tiny piece of debris.
These problems are also common with a camera that is not powering up correctly. To troubleshoot the issue further please view this FixYa tip that I wrote on the issue which is quite comprehensive in covering the fixes an ordinary consumer can reasonably try.
http://www.fixya.com/support/r3556007-camera_lens_stuck_or_wont_retract
Hope this helps. Thanks for using FixYa.
Sep 12, 2011 | Cameras
I mistakenly dropped my digital camera a few inches when the lens was out.When i tried putting it off to know if the lens would go back in,it didnt move so i forcefully pushed it back inside.Now, when i...
You've likely jammed the zoom motor in the lens. You're correct in thinking that the camera can't work without the lens out. With it being physical damage repairs wouldn't be covered under warranty so you either need to pay to have it repaired (if that's even possible, it varies camera to camera) or buy a new camera unfortunately.
May 11, 2011 | Cameras
I got and fEE... and figuered out it means error!!
This might be a long shot, but on the lens section of the guide shown below, it notes ,,,,
Non-G lenses will have an aperture ring on the base of the lens where it's attached to the camera. Set this this ring to the smallest aperture (largest number), usually in orange and 16, 22 or 32. There usually is a lock to keep this ring set there, since if it comes off that setting you'll get an error message (fEE) from most cameras.
Full guide is here:
http://www.kenrockwell.com/nikon/d90/users-guide/index.htm
Hope this helps
Mar 06, 2010 | Nikon N60 35mm SLR Camera
My l100 samsung camera beeps three times when i push the power button and then wont come on? I tried to take the battery out and put it back in but that didnt help. i also took out the memory card but that...
Lens motor stalled.
Checkout the price of a repair at Samsung suppor.
Had this happen with the lens stuck in the retracted position. Rapped the camera on my palm to jostle the lens a bit, turned it on and back to normal.
Feb 07, 2010 | Nikon D100 Digital Camera
My 9 month old camera (Nikon s210 coolpix 8.0mp) that I
Hi!
It sounds like the lens focus is stuck. If you don't have experience in camera repairs, you should give it for a repair to your local Nikon service center or other camera service center.
Tom
Jul 31, 2009 | Nikon Coolpix S210 Digital Camera
Zoom error, Fujifilm J150w
I just pulled apart the camera, everything inside was intact. No cogs broken. couldnt find anything to fix (not a camera expert by the way).
In desperation even put some WD40 on the lens barrel - still no luck.
Camera turns on - barrel is stuck out. Wont zoom, wont go back in and wont take a photo.
Daughter's camera and she says she didnt drop it but just saw it on her desk with the lens out...
Would be good if someone could shed some light on the problem.
Jul 05, 2009 | Fujitsu Cameras
How can i fix a stuck lens on a Nikon COOLPIX L11?
I have the same problem with my nikon coolpix s200. After 2 months the lens of my camera won't go inside. On the lcd screen stood lens error. I went to a shop with this problem. He took the battery out of my camera and press the off and on button for a while. Then he put the battery back in the camera and press the on button. The lens of the camera was now going inside en outside and inside and outside with a strange noise. And also on the screen stood lens error. Okey, the lens is inside the camera. But how can I fix this camera? What is the problem? What have you done? Please let know..!!
Jul 13, 2008 | Nikon COOLPIX S200 Digital Camera
IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
Jun 05, 2008 | Olympus i:robe IR-300 Digital Camera
Sony Cybershot Lens Stuck inside!!!
Gently tap it on a table or flat surface a few times. Worked for me!
Jul 06, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Acer Aspire 4720 Notebook Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
