Question about SanDisk Sansa e250 MP3 Player
The unit will not turn off is stuck - SanDisk Sansa e250 MP3 Player
  • kakima Sep 07, 2010
    Is there a padlock showing on the screen? If so, slide the switch on the top of the unit near the headphone jack away from the jack to unlock it.
    If that's not it, reset the unit by pressing and holding the power button for fifteen seconds before releasing it. Does that do any good?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
Having gone over a month without a response to my query, I assume one or the other of my two suggestions solved the problem.
Posted on Oct 13, 2010
Hi, my delonghi manifica 4200's infuser is stuck high up to the right and is completely stuck, tried moving motor etc after reading fixes on here but it's not moving at all. Any advice please? Neil
leave the power point turned on.
turn off machine at the power switch (on the unit)
This should bring the unit down....or
Turn off completely unit and power point and the just turn on the power point...this should bring the unit down
Nov 14, 2016 | DeLonghi Coffee Makers & Espresso Machines
Garbage disposer hums, but will not turn.
You sure you don't just have something stuck in it? Most units have a hex bolt on the bottom of unit, that you use to turn motor backwards to unclog stuck blades.
Mar 09, 2015 | Miscellaneous
Brew unit stuck miele 4062
This has happened to me many times. Just turn off the main power, turn it back on open the door and close it so the brew unit repositions itself. The unit should come out easily now.
Jul 07, 2014 | Miele CVA 4062 Stainless Steel
Stuck flywheel, disposal will not run, humminf noise Model: GFC525F GE
something is stuck in it, the humming is letting you know that its stuck. assuming you dont have a disposal turning wrench try this. unplug the unit under the sink. using an old wooden broom handle,, place it inside the disposal , and try and turn the unit. once you free it up, use a flashlight to look inside and remove whatever is jamming it up. once this is done, plug it back in and try it again. if the humming has stopped and it doesn't turn on. at the bottom of the unit is a reset switch. push it in, and try it again ( turn off the power as you rest it)
Apr 21, 2011 | Kitchen Appliances - Others
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
Mar 04, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
When I turn on my unit the display is stuck with REMOTE ON
Move the remote to another room to test. It is possible a button on the remote is stuck on.
Beyond that , it probably needs to go in for service.
May 16, 2010 | Sony CDP-CX400 400-Disc CD Changer
Blades don't rotate when unit is turned on
does the unit make any noise?? if so its prob bad..replace!....if no noise check under unit, there is a small red reset button..push up firmly.. turn on...keep fingers out please!
Mar 15, 2009 | Microwave Ovens
Nuvi 780 stuck in "loading maps"
On the back of the unit there should be a reset button, press this in till the unit starts to turn on again.
~Phil
Jan 10, 2009 | Garmin nuvi 780 GPS
Standby button stuck
Hello. Check all of the buttons on your unit to make sure that they are not stuck...you can feel the click they make as you push it then they pop back out as your finger pulls off. Any stuck button will lock up your microprocessor and keep the unit from turning on. All other problems will require a consumer electronics technician to trouble-shoot the turn on circuit. If you know how to use a meter and know how to solder\unsolder and require further assistance you can contact me. Good luck.
barneyluc
Oct 19, 2008 | Onkyo TX-SR601 Receiver
SanDisk Sansa e250 MP3 Player Logo
19 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
