Question about LG WM-2277HW Front Load Washer
LG Washer I don't have the original manual on my LG washer. Everytime I try to wash it stops after about 5min. The screen says IE. What does that meen?
    Novelist:
    Champion:
  • 216 Answers
Greetings julie312,
The "IE" message can mean that water is not entering your dispenser. If you have traces of lime in your water or very hard water, your water inlet hose can become clogged quite easily. To clean this please do the following:
Turn off the inlet water tap.
Unscrew the water inlet hose.
Clean the filter using a hard bristle brush.
Replace filter and hose, tighten water inlet hose.
Your water inlet hose is found on the back of your machine. It is recommended to clean this every few months.
You can also find a link to your manual by following http://us.lge.com/products/model/detail/home%20appliances_laundry_washers_WM2277H___yes.jhtml
I hope this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
Posted on May 14, 2008
WHAT DOES IE STAND FOR?
LE = MOTOR IS BLOCKED
Faulty open circuit wiring to stator assembly.
Sep 20, 2014 | LG WM2688HWM TROMM SteamWasher
Washer model WM2016CW - IE code appears - in order to continue, machine has to by-pass a wash. Repairman stated that machine is functioning in good order and the washing machine is not the problem. He...
They have a small gauze type filter which fits in the pipe end going into the rear of the machine.
Never had a problem with any other Hotpoint machine I had fitted other than LG which showed a similar fault .
Try Using the original pipe not the LG Pipe as well to see .
Nov 02, 2017 | LG WM2016C
IE error on LG intellowasher
IE = Inlet Error. Turn off supply valves to hoses and remove hoses from back of machine. Pull inlet screens out of the washer where the hoses were previously attached, clean them out, and re-install. That solves the IE problem about 95% of the time. (Usually, you only have to clean out the cold one.)
Jan 02, 2011 | LG WM-1290FHB Front Load Washer
LG Washer stops when it gets to rinse cycle
Code flashing IE? The code means the machine is not getting enough rinse water. Remove the hoses from the back i=of the machine, pull out screens, cold water is blue tab inside connection on washer, hot water is red. Clean screens and insert them back into the appropriate connection. Use a stiff brush and water to clean. Reset the machine by disconnecting power, press start/pause button(blue button on right) for at least five seconds, reconnect power.
Oct 31, 2010 | LG WM2277H Front Load Washer
The washer is saying IE and not woking
IE = Inlet Error. Check the screens, inside where the hoses attach to the machine.
Apr 27, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
IE error code
IE. is inlet water valve error.
Make sure someone did not turn off the water to the washer!!!!
Remove fill hoses and check filter screens on washer and fill hoses and clean if needed.
If problem continues water valve may need to be replaced.
Jan 16, 2010 | LG Washing Machines
I have a LG washing machine, model WM2277H. Ready to wash clothes, put the machine on but no water is entering the machine. water valve is open, cleaning the filter inside the hot and cold tubing to the...
Kinked inlet hose. Screened hose washer in inlet hose plugged. Frozen water supply pipe(s). No power to washer inlet valve(s). Old inlet hoses with separated layers, blocking water flow under pressure.
Turn off valves, remove from machine end, put in bucket and turn on valves to make sure you have water up to machine. Now work back to find why you are not getting water into machine.
Jan 02, 2009 | LG WM-2277HW Front Load Washer
LG FRONT LOAD WASHER ERROR CODE IE
LG has general error codes for all there appliances and the "ie" error code is for the water supply. You either have a kink in your hose, water vavle shut off, or the bad problem your pump is bad.
Jul 30, 2008 | LG WD-1045FH Front Load Washer
LG WM-2277HW Front Load Washer Logo
153 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
