Question about Ricoh Aficio SP C811DN-DL Printer
What is the sc367 error code mean on a spc 811dn.
3 Suggested Answers
  • 95 Answers
SOURCE: service code SC 548 on a Ricoh Aficio SPC 811dn
Fuser code. You have to enter service mode to reset it. 5-810 and select execute to reset.
Posted on Apr 23, 2009
  • 86 Answers
SOURCE: HOW TO ACESS SERVICE MODE RICOH SPC 811DN
Press the UP and DOWN arrow keys together for 5 seconds or more, and then press the OK key.
Posted on Jan 16, 2010
Ricoh Aficio SP C811DN Printer. after printing 9 pages it will stop and displays CS367 error code saying 'Functional problem turn power switch off then on. Can you tell me what that means and how fix...
SC367 is a toner density error having to do with yellow. If you've tried turning the machine off (with the power switch on the lower left side) and turning it back on and that doesn't help, your next move should be to replace the yellow photoconductor unit (PCU).
Thanks for using FixYa!
Feb 08, 2011 | Ricoh Aficio SP C811DN-DL Printer
How can I reset a SC 547 error on a Ricoh Aficio SPC 811 DN? I've already replaced the fixing unit.
Hi
Error code sc 547 means "Zero cross signal malfunction". This error appears due to a faulty power supply. This error code may also appear if the input board is defective or the BIC Unit is defective. Turn off the printer and unplug the printer for 30-40 minutes and check if the error still appears. If you see he error still appearing then try and rest it using the following reset method--
To reset the SC code by entering SP5810 and select 1.
Now hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, you'll need to check and replace the Power supply or the Input (IOCC) boardt.
Hope it helps...
Oct 11, 2010 | Ricoh Aficio 150 Copier
Error code e03-40
---Copy Density Sensor output adjustment-----
1. Sensor connector is disconnected.
2. Sensor is defective.
3. SPC PCB connector is disconnected.
4. SPC PCB is defective
there is a sensor in the drum unit that measures/sensors toner density on the drum. the sensor is usually dirty and needs a clean. there could be a number of causes so a technician needs to be called.
May 01, 2010 | Panasonic Workio DP-3520 Copier
Jan 04, 2010 | Ricoh Aficio SP C811DN Laser Printer
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Panasonic workio DP-3530 error code E01-20
e1-20 means " laser unit horizontal problem" its ether your lsu is not connected or defection or you spc board is not connected or defective.
good luck
Nov 19, 2008 | Panasonic Workio DP-3530 Copier
E03-40 error code
panasonic dp-4520 copier. e4-02 error code
Jun 19, 2008 | Panasonic Workio DP-3520 Copier
Panasonic DP-190 Error Message
E01-31 is a scanning lamp error"does not turn on. possible solutions. scanning lamp cable defective.
spc board or sc board is defective
Jan 03, 2008 | Panasonic DP190 All-In-One Laser Printer
Ricoh Aficio SP C811DN-DL Printer Logo
293 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
