Question about Panasonic NN-S953 Microwave Oven
Fuse keeps blowing Found out we shouldn't have it
Fuse keeps blowing Found out we shouldn't have it connected to an extension cord, which we did. But need to know if I can use a 20AMP fuse or if I have to use an 18AMP fuse?
  • Panasonic Master
  • 43,501 Answers
A 20 will work but I would change it to the correct on as soon as possible...
heatman101
Posted on Sep 10, 2010
About my Emerson microwave oven; What can cause the fuse to blow in my microwave oven?
That would be a problem with a door switch, door switch mount, or hinge.
See my help file on door switches here:
http://www.microwavecontrol.com/doorsw.txt
Oct 01, 2016 | Emerson Microwave Ovens
For some reason , my microwave keeps blowing the fuse. Every-time I plug it in , it sparks and blows the fuse/trips the breaker. I dont think its the door switch because it has nothing to do with being...
Your unit is drawing way too much power, especially before you even activate the heater & fan modules. Could be dozens of causes. First line of defense is to check the power cord for a short. Consider your expertise and unit's warranty before opening it up. Check, trace and/or replace the cord. Don't ignore radiation exposure warnings, some shields are critical.
Oct 08, 2013 | Microwave Ovens
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
The oven is totally dead. No light, fan etc. Replaced fuse internally, found no current at the fuse. Outlet has 120 v. Oven was run empty prior to going dead! Any thoughts?
check power between power cord connection and inernal fuse,start at cord connection and work way to fuse conn.eliminating possibe problem area
Oct 11, 2010 | Maytag MMV5000 Microwave Oven
Do my microwave havea fuse because it wont turn
Yes, there is usually a 2 amp fuse located on the inside near the where the electrical cord feeds into the power supply. There might also be another fuse as well, be sure to check all around the power supply to be sure that there is only one fuse.
Plugging your microwave into an extension cord that is not rated for its use, or plugging the microwave into an un-grounded electrical socket could cause that fuse to blow.
I hope that this information was helpful to you in any way.
Apr 27, 2010 | Sharp R306L 1100 Watts Microwave Oven
Blows fuses, no visible overheated areas.
there is a short in the unit, if the fuse keeps blowing when you replace it you will have to check for a short either in the power cord or transformer.NB: HIGH VOLTAGE!!!!!
Mar 25, 2010 | Microwave Ovens
I have a J HP60G 002 GE Microwave (older)keeps
If it blows the line fuse instantly when you push start.... it is either a shorted HV capacitor or shorted monitor switch.... most likely.
Sep 13, 2009 | Microwave Ovens
My ge profile microwave keeps blowing its fuse. i
Don't increase the amp size of the fuse this could cause the wiring to get hot or component to get hot and catch on fire. Is the fuse the main fuse the one that the power cord goes to?
Sep 11, 2009 | Microwave Ovens
My Emerson Microwave Model # MWG9111SL keeps blowing fuses..
You have a shorted high voltage capacitor.
Here is a link you or someone you know can use to test it, but please read the safety info:
http://www.gallawa.com/microtech/cap_test.html
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Nov 24, 2008 | Emerson Black Microwave Oven
NO POWER
Inside the microwave is a fuse. If you can, try plugging the microwave into a different outlet (use an extension cord). If it does not power on, you have likely blow the fuse. If you are technical, you may look into replacing the fuse yourself (you will have to remove some parts of the microwave exterior to get to the fuse). Otherwise, if no longer in warranty, you will need to have a shop or handyman replace fuse.
Mar 29, 2008 | Microwave Ovens
Panasonic NN-S953 Microwave Oven Logo
379 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
