Question about Intermatic & Indoor/Outdoor Rain Tight Timer
I installed an Intermatic T-101 to control a filter pump for an above ground swimming pool. Ran a couple days and then stopped . Clock is working, but the trippers for "on" and "off" are not working. Is the single-pole single-throw the correct function, or do I need a double-throw switch? The motor is 120VAC.
  • Intermatic Master
  • 5,245 Answers
Open following link to double-check T101 wiring.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on May 10, 2012
buffalonyman
  • 1865 Answers
SOURCE: Intermatic T 101 24 Hour Dial Tine Switch Does Not Turn On
Its 10 years old, replace the whole timer switch
Posted on Jun 18, 2009
protek480
  • 1723 Answers
SOURCE: Intermatic T101 does not turn on using the
There are two different trippers. 'On' and 'off'. The off will not turn it on. Get an 'on' tripper.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 26, 2009
protek480
  • 1723 Answers
SOURCE: My intermatic timer won't trip back on
I don't think the timer runs on 240 volts does it? You can switch 240, but the timer uses 120 volts to run. You might check the connections and timer clock rating more closely. Also, the 'off' & 'on' trippers are different, make sure you use the right one.
gotgeek2
  • 565 Answers
SOURCE: intermatic timer for my pool pump - clock is not running
Usually the timer motor is bad when that happens. Replacement timer motors are available from websites like this one:
http://www.aplussupply.com/intermatic/timermotors.htm
Be sure to get the right voltage timer motor. Intermatic T101's and T103's use a 120 volt timer motor (Cat# WG1570) and the T104 uses a 240 volt timer motor (Cat# WG1573).
If you don't want to mess around replacing the timer motor, you can purchase a new timer, and as long as the existing enclosure is in good shape, just swap out the guts.
Posted on May 14, 2010
MOTORWIZJ
  • 1384 Answers
SOURCE: I use the timer T104P3 to switch the pool pump
LOOK HERE ON EBAY.. ITS CALLED A TIMER MOTOR.. REMEMBER TO VOTE..THANKS...... JAYhttp://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170493987778&ssPageName=STRK:MESELX:IT#ht_2761wt_1227
Posted on Jun 02, 2010
Where does the hose from the skimmer go in filter or pump
skimmer goes to intake of pump out of pump to filter in out of filter to pool return
May 30, 2014 | Intex 1500 Gph Swimming Pool Filter Pump...
Tip
How To Connect Hook Up Use Above Ground Swimming Pool Vacuum and Hose With Sand...
<utube src="YEW-QUyP2Iw"></utube>This video will show you how to connect your above ground pool vacuum and hose to the sand filter on your swimming pool.
on Aug 03, 2013 | Pool & Spa
Filter stopped working
I would agree...
they are just a Toy! Sorry, I don't mean to be sarcastic, but that is how they are manufactured, not designed to last.
My customers come into my store all the time asking for pump replacements, and if they don't want to upgrade to a Real Pump and Filter, then I send them to:
Warranty Return Policy
To purchase another replacement toy,, like:
  • Intex
  • Wet Set
  • Krystal Klear
  • Cloud
  • Fun n' Sun
  • etc
and you get this...
When the pool s are purchased from walmart, kmart, target, etc
But...
If you can find it in your budget to upgrade, you can still use the same vessel, upgrade to a real filter & pump package set.
like this one:
Hayward S166T92S Pro Series 16 Inch 1 Horsepower Top Mount Sand Filter...
Don't replace with the picture above.
Sep 11, 2013 | summer escapes 16 x 48" Frame Pool
I need to know how to set this timer for a large swimming pool, and how long I need it to run, to keep it clean. I believe it is about 35,000 gals., in-ground pool.
You have Intermatic mechanical timer connected to swimming pool pump/filter.
Open following link to read about setting timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Lift and rotate dial until current time is lined up with stationary pointer.
Put on-off trippers on outer edge of dial.
Timer comes with 2 sets of trippers, and you can order replaceable trippers. Up to 12 sets of trippers can be added to dial for a total of 12 ON and 12 OFF events each 24-hour period.
For 35000 gallon, pump should run at least 6 hours each 24-hour period. During freezing weather, if pipes are above ground, you can remove trippers from dial, set override lever to ON position, and run pump 24-hours to prevent frozen pipes.
Jul 12, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I bought a house that had an intermatic t104 running timer running the pool pump. It worked for a little while then the clock stopped turning. The manual switch still worked to turn on the pool. I...
If you only have a Black wire, White wire and a ground wire, you are only wired for 120 volts. For 240 volts you have to have two Black wires or a Black and a Red as well as a White (neutral) and a ground.
Jun 21, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
HOW TO WINTERIZE AQUAMATE ABOVE GROUND SWIMMING POOL PUMP
Open the plugs on the bottom front of the pump pot and on the pump housing itself. These two plugs will do the pump and just the pump. You should have simmilar plugs on the filter, heater, chlorinator and any other equiptment on the system.
Oct 13, 2010 | Hayward Sp1580x15 Power Flo Lx 1.5hp...
2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only: how to converte to larger filter...
You can simply buy a larger pool filter that is designed for pools in your size range. Look for one that is designed for smaller above ground pools. You can find lots of different pool filters at backyardcitypools.com.
May 17, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
T104-50 clock not working
YOU CAN LOOK THREW THE LITTLE WINDOW TO SEE THE GEARS TURNING ON THE CLOCK .. IF NOT .. Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIX ON EBAY
TO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ. .. VOTE PLEASE THANKS... JAY
Oct 07, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Salt water system flashes 90
Hi. Have you cleaned the flow sensor? Make sure that it moves freely throughout it's full range of motion. Sometimes things eventually will fail. If you have completed your checklist and the above mentioned then the replacement of the sensor unit seems to be the next logical step. Happy swimming
Aug 18, 2009 | Intex Automatic Salt Water System for ...
Problems with Intex Krystal Clear Model 635 Pool Filter Pump 1500
No, the pump should not be noisy. It sounds like you have picked up a foreign object in the pump housing. you may have to pull the face off to determine. OR the pump/motor is indeed defective and should be returned.
Mar 15, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
43 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
