Question about HP Pavilion dv2700t Notebook
When I turn on my notebook, there is no respond and the screen remains blank except for the few buttons on the top of the panel are lighted up. Please help!
cpenzes
  • 1102 Answers
SOURCE: blank screen when i turn on my pesario 2500 lap top
do you hear your fans running
it starts but your screen is black
if you do hear the system running then i would believe you need a new video card.
have you made any changes to the system
Posted on Feb 12, 2009
papa_sanjay
  • 67 Answers
SOURCE: turning on but remains blank screen
it may happen that your extetnal (VGA Display) is enabled, this will disable your LCD Display.
just press Fn key and look function keys where monitor symbol is drawn ( that is F7 or F8 key. (turn on laptop then press Fn + F8/F7)
Posted on Aug 20, 2009
LaptopExpert
  • 458 Answers
SOURCE: my ACER netbook turns on but the screen remains
After switching off the aa1, when trying to turn it on again, it just shows blinking leds and the fan is turning. But the screen remains black.
If your aa1 does like this probably its BIOS has been damaged...
Luckily the Acer Aspire One has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore.
Please note that the process I'm about to describe is only meant for emergencies and may void your warranty, so use at your own risk.
1) Format a USB memory key with the FAT mode.
2) Download the latest version of the BIOS from Acer support website:
3) Extract the files from the zip and put both the FLASHIT.EXE and the BIOS file in the root directory of the memory key.
4) Rename the BIOS file to ZG5IA32.FD and then remove the disk.
5) Turn the AA1 off, insert the battery and connect the AC adapter.
6) Insert the USB Memory Key into one of the USB port of the Aspire One.
7) Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on.
8) Release Fn+Esc after a few seconds, the power button will be blinking.
9) Press the power button once. The AA1 will start the BIOS flash, do not interrupt for any reason. After some minutes the power button will stop blinking, and then the AA1 will reboot. Wait till the AA1 has completed all this operations.
If everything has gone right, the BIOS is flashed and all settings are reset to default.
Posted on Nov 16, 2009
  • 5 Answers
SOURCE: screen not working
did you connect external desktop?  when you switch the led is on. tell  me more information
Posted on Mar 15, 2010
  • 155 Answers
SOURCE: HP tx2000 - black screen.
Hi
The problem you are experiencing is related to the screen of your Hp.
All you need to do is to is to get to a computer store and get your screen replaced.
You can not fix a damaged screen.
GOOD LUCK
Posted on Jun 17, 2010
Toshiba Portege r200 was working normal (up until yesterday). Today, when I first turned it on, the fan was on and it sounded full blast, but screen remained dark (blank). I held power button until it shut...
The part that supplies the power to the screen is gone. I recall is is called the 'exciter'. They can be replaced, so take it to a computer repair shop. Same thing happened to my Toshiba.
Aug 18, 2017 | Toshiba Portege R200 Notebook
Television goes blank without warning for undetermined time
Power supply board have problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 02, 2010 | LG 32LC2D Television
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
When I turn on my laptop only the lights tern on,
remove the battery and power cable and hold the power button for 5 to 10 sec and then connect the power cable and reset the battery or try diffrent ac adapter or wall unit
Aug 16, 2009 | HP Computers & Internet
When i push on the on/off button, the screen lights up but is blank. I have tried shutting it down, pulling out the battery and trying to start up again many times. The screen comes on, lights up, but...
Try plugging in an external monitor. Not a flat panel, just a regular CRT is preferred. See if you get a picture. This will tell you if it is the LCD screen on your laptop or a CPU problem.
Aug 15, 2009 | Dell XPS M1330 Notebook
Install Radio
ok you will see to screws at the back unscrew them and take it out then smash it becase it is gay
Jul 14, 2008 | 2002 Audi A4
Display 11
your control must be fried...dacor fault codes are f0 to F8 the display must be faulty..
Aug 25, 2007 | Dacor ECD230 Epicure Electric Double Oven
HP Pavilion dv2700t Notebook Logo
176 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
