Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Humming motor - KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If everything else seems to be working fine and you just hear a hum sound from the motor and it won’t run then it means that the motor has gone bad and should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 07, 2010
My Frigidaire fex831fs4 washer motor hums but wont start.i took belt off.still hums no start even when timer is not set to run.if I close lid motor hums then kicks out then it trys again.thanks 4 help
I appreciate your post, Mike!
Based off what you have described your Frigidaire washer motor will hum and not start. In order to test each component you would need to have the proper electrical equipment. I would recommend contacting a professional technician for proper repairs. They will have the necessary equipment needed to complete your repair. Hopefully this is helpful. -Matt
Aug 31, 2015 | Frigidaire Dryers
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
f you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 18, 2011 | Kenmore Dryers
MY DRIER JUST STARTED MAKING A LOUD HUMMING SOUND WHAT DOES THAT MEAN?????
You must see if this is the hum of the motor or that of a mechanical friction of the motor assembly. If the motor is humming please check the capacitor that is connected to the motor, change with the value specified on the capacitor.
If there is hum on the drive use good lubrication remove and reset.use degreasing spray to ease off friction
Sep 24, 2010 | Kitchen Ranges
Makes a humming sound in the back, and code comes up LE at start of the wash
if the motor is humming there is a fault with the motor,,it could be its just jamed up,,,however if its humming its going to get very hot,,,that wont do it any good at all, check the motor brushes first also check its not a capasitor type motor,,,if the cap has gone that will cause a hum in a motor as well
Aug 21, 2010 | LG WM-2277HW Front Load Washer
Whirlpool LER 6620 heats, but does not tumble.
if the dryer heats the motor should be good. if it hums its either runing or the hum is a stall noise . if belt is in tact then if motor were going so would the drum . so i think the motor isn't going just humming and the heat sw in the motor is stuck closed with lint and you need to replace the motor .. take the belt off and turn motor if it turns free . the blow it out good and reinstall belt and try again ..mm
Dec 03, 2009 | Dryers
Hums when turned on-won't turn over
belt may have broke. if you are hearing a humming sound . thats the motor .whitch is good, sounds like the belt broke or slipped off.
Sep 12, 2009 | Kenmore 73952 Gas Dryer
My blower motor will not start. it hums and gets very hot. i can spin the wheel with no resistance gmp075-4
Assuming you are spinning it when the motor is humming, if the motor runs after spinning it it could be the run capacitor (replace) or open/broken start winding in motor(need new motor). Humming should indicate the motor is getting proper voltage. If motor does not try to run by spinning then open run winding in motor (replace motor).
Aug 30, 2009 | Heating & Cooling
I HAVE A HUMMING MOTOR. ONLY YEAR AND A HALF OLD.
HI, it is possible that this motor was defective when it left the manufacturing plant. This AC hum you are hearing is coming form the motor and, this is a sign of damaged internal motor windings. you will need to replace this motor asap.
Jun 24, 2009 | LG Dishwashers
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
100 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
