Question about Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive
Hard drive does not respond - Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive
  • Maxtor Master
  • 27,725 Answers
Try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Posted on Sep 07, 2010
Transcend hard drive not responding
Are you getting errors? Can you be more specific. Is it found in device manager? Has windows assigned a letter?
Mar 20, 2014 | Computers & Internet
External keeps telling me not responding
Assuming your talking about an "external" storage device, such as a hard-drive over a USB connection... If the device isn't responding, and ASSUMING it doesn't need external power, and "should" operate over USB (most do)... then it's damaged. If it needed to be formatted, etc..you would get a different message. If it's locking up the computer, and not responding..it's simply bad and needs to be returned. Sorry :-(
Oct 18, 2012 | HEWLETT-PACKARD Hewlett Packard HP 2TB HP...
Keeps saying not responding
Your external hard drive has gone bad. You may even hear clicking coming from it.
My maxtor 500gb usb hard drive is not responding when I plug to my pc, so I can't access to any of my file
hello,
-make sure that the cables from the ext hard drive is properly connected like power if there is and USB -try other USB port -try other USB devices -try other USB cable for that Maxtor -try other computer
the reason why you are doing that is to know if the USB port is broken of if the ext hard drive is not responding.
cheers.
Feb 24, 2011 | Maxtor BASICS Personal Storage 3200...
My maxtor external hard drive stop responding. How do I getit back? I've changed it from it's original USB slot. I have the Maxtor OneTouch II, 100GB, 8MB CACHE, 7200 RPM
Usually Matox is very fragile, it responds to any little error. Does it make any funny sound inside it?
Check the usb wire if it is ok, or you leave it for a while and try it later to see if it responds.
Plug it to your system using an IDE cable, go to your computer setup to see if your system recognizes it. If it does not then try setting the jumper at the back of the hard disk. But if your system recognizes it, use a start up to format it and monitor the formatting if it shows "recovering allocation unit" if it does, it means the hard disk has Bad sector(s) which might be the reason why it is not responding. So you will have to partition it and use the part of the hard disk that does not have bad sector.
What usually cause an hard-disk to have a bad sector is:
  1. When a system is not shut down properly
  2. When power goes off the system unexpectedly
  3. When you remove from the usb without ejecting or safely removing first. (That is while using it as an external drive). and so on.....
I wish you the best.
Nov 10, 2009 | Maxtor Hard Drive
320 GB Inoi media hard drive will not play on TV
Make sure you are using the original composite cable and check the connections.
If you are using a SCART cable check the connections.
Also make sure the remote control is responding to media player.
Check the drive responds when you press the “STANDBY” button on the remote.
If the drive responds then the remote is working fine. If not change the battery and see whether it helps.
Also try on another TV and see whether it works. If not back up all the data on the drive and format it and see whether it helps.
All the best!
Aug 11, 2009 | INOi 320GB INOI HIGH DEFINITION 7200 RPM...
Remote won't connect with the 320gb Inoi media player
Can you please tell me, whether the drive responds when you press the “STANDBY” button on the remote?
If the drive responds then the remote is working fine and the actual unit is faulty. If the drive does not respond then the remote is faulty. You need to buy or get a replacement from the seller.
All the best!
Apr 05, 2009 | INOi 320GB INOI HIGH DEFINITION 7200 RPM...
Lacie hadr drive problem
I am looking for some help with the same problem with a Lacie External Hard Drive, does anyone respond to these posts?
Feb 22, 2008 | LaCie d2 Extreme 250GB External with...
Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive Logo
26 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
terminalcon
Jerry Umali
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
