Question about Frigidaire Refrigerators
I have a side by side FRS26ZSH Frigidaire Gallery- Professional Series. I've lost water pressure in the door water dispenser and ice cubes are tending to be hollow. Can you suggest a solution or direction?
SOURCE: Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Posted on Sep 20, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
aborcass
  • 2651 Answers
SOURCE: Ice and Water dispenser
no manulal reset or fuse, buth tere is ususlly a "child lockout" feature prevent ing the dispensor from operating. check to see if the control has been placed, on, or perhaps the door is not closing fully, another reasom for the dispensor to stop
Posted on Jan 20, 2009
  • 117 Answers
SOURCE: frigidaire gallery pro series model frs26zsh water
Mor than likely you have a clogged defrost drain. Drain is located at the bottom of freezer compartment behind the back panel. You will have to remove the panel and blow out (or vacuum) the drain hole. Hope this helps
Posted on Jul 31, 2009
  • 146 Answers
SOURCE: Frigidaire Gallery Professional Series -
you will need to replace the water inlet valve, this runs your water and ice,, before you replace it take your water line off and hold it in a pot, then have someone turn the water back on , this will let you know for sure you are getting water to the valve,, if no water comes out then you have a water line prob,, have that fixed then hook it back up and turn it on, then you will need to run the water for about 2 -3 minutes to purge the air out of the line,,, if you rplace the valve you will need to purge also
Posted on Jan 19, 2011
Ice dispenser frigidaire
Hello Friend, thank you for allowing me to assist you!
From what you have described it sounds like the issue lies with the door switch, auger motor, or a faulty ice door flapper (the flapper that opens to allow ice to dispense). In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your Frigidaire refrigerator. Best! - Z
Sep 04, 2014 | Frigidaire Gallery Side By Side...
Frigidaire Gallery Professional Series - FRS26ZSH My ice and water maker have stopped working. First the water stopped then about 5 days later the ice maker stopped.
Jan 19, 2011 | Frigidaire FRS3R5EMB Side by Side...
Power to the ice maker/water dispenser seemed to have shut off. Ice maker is still making ice, but the dispenser is not working. Is there a fuse or something?
frigidare 36' side by side. makes ice, nothing comes out of the door dispenser, auger truns. prior to this it would only give crushed ice even if set on cubes
Dec 06, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire gallery pro series model frs26zsh water leaks out somewhere goes into backside of freezer eventually goes down to underside of bottom basket and freezes
Jul 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Chilled Water supplycomes out very slow. Ice maker
Its time for a new filter, the water filter will be in the upper right hand section of the freshfood section, or in the kickplate at the bottom
Jul 15, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Jan 17, 2009 | Frigidaire FRS26R4A Side by Side...
hi there,
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Refrigerators Logo
43 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
