Question about Saeco Vienna Digital Coffee Maker, Espresso Machine
Leaking Water after each Brew
A couple of weeks ago I noted that whenever I brewed a cup of coffee or espresso, the volume was cut dramatically on the first brew. My Saeco Vienna would leak clear water (about a 1/2 cup) from the small holes in the bottom of the machine. I removed the "catch tray", took out the dreg drawer, removed the grey coffee compression unit, to find there is no access to the "inside" of the machine to see where the leak is originating from.
When the machine is not in use, there's no puddle of leaked water. The puddle forms only after getting a great cup of coffee. I love the coffee....hate the water leaking on the countertop. Help!
  • Anonymous Mar 12, 2014
    B31 is leaking water onto countertop instead of brewing
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
I have the user manual for your machine after reading it there could be many tiny thing you can do to fix that problem.but they are mostly pictures follow along instructions i can e-mail this manual to you in pdf file format if you wish.
Posted on May 14, 2008
    President:
  • 2,712 Answers
Hello doc G,
There is a rubber valve (usually spring loaded ) which is resident behind the shower screen. This may be old, or become hard and will need replacement. You will have to undo the shower screen to get to this valve. However, if your machine is under warranty, I would advise against this as it would void the warranty. Best call the manufacturer/ point of purchase in this case.
Hope that helps..
IrishDruid
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson May 14, 2008
    Found this solution elsewhere. Have a go at it first, as it is the easier to do..
    "there is a drain located in the back of the machine that drains into
    the drain tray. If this drain is clogged (like mine) when ever you
    brew, the small excess water, instead of draining as it should into the
    tray, drains into a very small reservoir that holds the slight excess
    of water that occurs with every cup. When the reservoir finally fills
    up, it pours over the lip and into the machine and all over the place
    missing the drain tray. It is messy.
    The solution is to remove the brew group, look into the back where the
    brew group inlet nozzle fits, and you will see the discharge nozzle
    leading down from the top left and into a reservoir. You cannot see the
    drain because it is behind the axle that drives the group, but you can
    feel it if you stick your finger in and down to the right. You can see
    its discharge port, down at the drain tray. Clean it, until you can run
    clear water into it and see it drain out the bottom drain port into the
    drain tray, which you should reinsert before you pour water."
    Hope that helps..
  • Swilin Sampson
    Swilin Sampson May 18, 2008
    Just checking to see if your issue is resolved. If it is, please assign a Fixya rating for the Expert whose advice guided you to a fix.
    Cheers!
  • Swilin Sampson
    Swilin Sampson May 21, 2008
    Just checking to see if your issue is resolved. If it is, please 'accept' the solution for the Expert whose advice guided you to a fix.
  • 3,037 Answers
Please read this link for more information on the problem you are experiencing which is quite normal after much use from a coffee maker
http://www.wholelattelove.com/articles/espresso_machine_repairs.cfm
Please let me know if you have any questions about the article and I would be happy to answer them.
Basically you will have to replace the rubber valve and this article tells you how to
  • Benjamin Patri
    Benjamin Patri May 19, 2008
    Please let me know the current situation with this problem, and if you were able to fix it, then rate my solution as I appreciate any and all feedback that I get. thanks
    Sergeant:
    Champion:
  • 427 Answers
I have the same coffee machine, not really familiar with the problem. I would open up the coffee machine a little bit, and see if all of the water connections are secure. Im pretty sure there is a little conection piece that sometimes comes loose. Try running the machine while you have a look at it open, you may find the leak.
    Genius:
  • 1,447 Answers
Did you already checked on the rubber as well are parts that are loosely reattach, try dismantling it and reinstall all parts and make sure that they are installed tightly. heat produces moist that acumulates on it thats why..
HB flex brew model 49995R doesn't brew a full cup of coffee
If it is only 3 weeks old, then dig up the receipt and return for an exchange.
Mar 02, 2015 | Coffee Makers & Espresso Machines
!0 Cup home Bunn. Does not brew the number of cups of water coffee (water) in craft. 8 cups of water 6cups of coffee.
If you don't brew often enough you will loose a small amount of water in the tank due to evaporation while the tank heater comes on and goes off to maintain the proper brewing temperature, so if it has been a while since you last brewed, without coffee in brew basket put a carafe of water thru the brewer, you will get less than a full carafe out because it fills the evaporated space in the tank first then uses the rest to brew. Once your tank heater shuts off usually 5 minutes on less you will get out all the volume you put in.
Oct 11, 2014 | Bunn 10 Cup Home Coffee Brewer
Leaking water
If it's clean water which runs out, check the hoses going from the water tank to the pump then through the boiler to the brew group. If coffee is running out instead, then it's the spout going from the brew group to the cup. I know Saeco's not Juras but they all function the same way.
Mar 23, 2013 | Capresso Jura-13204 Impressa E9 Automatic...
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
Won't finish brewing
We were having the same problem of it quitting the brew cycle about 1/2 way through. We put a mixture of 5 cups vinegar & 5 cups water through followed by a pot of just water and now it works like new. The vineagr must clean some sort of built in sensor.
May 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
Mar 10, 2008 | Coffee Makers & Espresso Machines
Saeco Incanto -- no coffee coming out
After I posted this I decided to descale the machine again, even though I'd just done it a couple of weeks ago. After descaling and rinsing I tried running water through the brew group by pressing the pre-ground button, then holding down the big cup button. Still no water, but then I turned the little knob on the coffee dispenser counterclockwise, about half a turn. It worked! I rinsed it well, then made a cup of delicious espresso.
Mar 01, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Vienna Digital Coffee Maker, Espresso Machine Logo
107 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
