Question about HP Photosmart R927 Digital Camera
Any chance to assemble the lens together again if the front part, with the three pins, has been ripped off?
    Brigadier General:
  • 3,006 Answers
None at all, sorry. The camera needs so many parts replacing and then adjusting that it is totally beyond any hope of economic repair.
Posted on Sep 07, 2010
I have 2 pins (brush contacts) has broken in my sigma lens mount nikon 70-200 hsm apo 2.8 where can I find them
Don't try this at home. Even if you can get new contacts, you should open the lens and there is a great chance you can't put it back together correct. A Sigma certified crevice centre, can repair and give warranty on good functioning of the lens afterward. Perhaps it is just as expensive as buying the parts.
If you insist on doing it yourself, look on the website ifixit.com, where they show how to repair things. They also can help with tools and spare parts if you need such.
May 02, 2014 | Sigma APO 70-200mm f/2.8 EX DG HSM Lens
How to unlock a puk l
Call carrier and ask for PIN, PUC and PUC2 codes (usually 8 digits). Turn device on and when prompted enter requested code(s)
Jul 18, 2012 | HTC Full LCD Screen Display Touch Screen...
Drivers side headlight bulb replacement
  1. Open the hood to the 1999 Dodge Stratus.
  2. Locate the two headlight lens assembly retaining screws at the top of each side of the assembly.
  3. Remove each screw with the ratchet and a suitable socket.
  4. Place the screwdriver behind the lens assembly to assist in prying out the guide pins that secure and align the headlight assembly. Hold the lens assembly from the outside edge (marker light/directional light section) first and pry from behind with the screwdriver to unseat the guide pins. Pry from the inside end of the lens assembly to unseat the other guide pin.
  5. Pull the lens assembly out far enough to reach behind it and disconnect the headlight bulb wire harness from the back of the bulb. Or simply remove the bulb by twisting the harness and retaining ring counterclockwise and remove it as an assembly.
  6. Turn the marker light/directional light socket and wire counterclockwise to remove it from the headlight lens assembly.
  7. Remove the assembly from the front of the Stratus.
Feb 28, 2011 | 1999 Dodge Stratus
My nikon 70-300 mm g lens has a mold inside. how can i clean it
Unless you have the necessary tools to properly dismantle and assemble the lens that job is best suited for those that do. Even if you did manage to get it apart the chances of getting it back together and aligned properly while working on the kitchen table would be slim to none.
Jan 16, 2011 | Nikon AF 70-300mm f/4-5.6 ED Nikkor Lens
I dropped my camera (only a few inches) and now the lens won't open when I turn it on. How can I get this fixed?
A lens go in & out by using guide line. We called that part is LENS Guider/pin.
After drop down the camera the pin is damaged or the lens is out of guide line.
That's why it was stuck out side. But some how its go in and stuck again. With
out replacing the lens if you try to repair it then there is 99% chance of facing
same problem after few days. Cost near about the same like a new lens. Even if you
campier with new camera then a new lens + repair charges total cost near about a new
camera. If you have a luck any time that, if the lens came out again and not going in
then just give a light twist on the lens and try to on / off the camera. Some time it
will start working, if the pin not broken. But your symptom says that its broken. Thats
why its not came out. By the way watch the link for new lens & a video for how to replace
the lens. If you have a little knowledge about the electronic then you can take the chance
for replacing. But its on your won risk.
Jun 14, 2010 | Kodak EASYSHARE M1063 Digital Camera
Drove over something and ripped wires in front left of car- need the wires put back together
You may need to strip the wires and solder them back together, you should reroute the wires to where they will not do this again. Make sure to splice the wires well and wrap them with electrical tape. Also make sure you use the right gauge wire, 12 gauge or 14.
May 10, 2010 | Cars & Trucks
How do you clean inside the lens
canned air. if you take the lens assembly apart to try and clean it any other way, there's a slim chance you'll get it back together properly. plus, they thread lock it. it's usually air-tight, but if it isn't, used the canned air to blow the dust out. chances are, the dust is inside the projector itself and on the back side of the lens assembly.
Jan 26, 2010 | Lightware VP 800 Plus Multimedia Projector
REPLACE HEADLIGHT ASSEMBLY IN 2000 LINCOLN TOWNCAR
Open the hood and make sure the car and the lights are off.
Remove the plastic protective cover.There are 3 knobs,turn halfway and pull.Put aside and out of the way.
Remove the three pins that are holding the light assembly in place.These are flat rods with a little bend at the end.
Twist and un-plug the lights,now you can remove the whole lens.
The light bulbs can also be removed and replaced from this point.
Make sure all the bulbs are working before you put it back together.
Mar 13, 2009 | 2000 Lincoln Town Car
I droped my camera on the grond and it wont turn on.it fell the side of the lens
Theres a very good chance you are going to have it repaired by a Camera Repair person. I would really need to know the brand and model.
If it is a canon then it will most def. need a new lens assembly. they have metal pins which guide the lens and when they are droped the pins break out of place.
If it is a Nikon or Sony or Casio alot of times I have been able to push the lens straight and it will re-align itself and work perfect again. But that said I wouldnt be too forceful unless the camera is not worth fixing. In that case you really arnt risking anything other than the possibility of fixing it.
Jun 26, 2008 | Olympus Cameras
HP Photosmart R927 Digital Camera Logo
35 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
