Question about GE Ovens
On a GE monogram oven, one row of buttons don't work. Naturally it is the 1 thru 5 line of bake #'s.
  • dox4joses Sep 12, 2010
    I would like to try to fix this problem.
  • 3,083 Answers
This sounds like a faulty control panel. This is most likely a failed Oven Control.
I would advise that a reputable GE authorized servicer verify fault and repair this type of oven.
Wall ovens are potentially more complicated to service than a free standing range and many servicers actually prefer not to deal with a wall oven at all.
It could be something as simple as a cracked trace or solder joint, but you would have to disassemble it and inspect it carefully to determine that, and it might be possible to be resoldered. Otherwise, it will need to be replaced to restore functionality.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 07, 2010
I have a GE Monogram Built-in Convection Wall Oven (model no. ZEK737WP3WG) and the heating elements have stopped working. The electrical power is working, and the control panel, light, convection fan...
It is possible that a relay on the control board is bad. GE has a relay in the common circuit to the bake and broil element. this has been a problem in a few ovens I have repaired. Check for this it is usually an orange relay on the board.
Apr 27, 2014 | GE Ovens
GE Monogram 30" built-in oven turns itself off after a few seconds.
Likely you need a thermal cutoff replaced near where your heating elements are. It senses the fault and shuts down. You can but an after market thermal cutoff from most any electronic parts supply, and maybe even from an appliance parts supply.
Nov 12, 2013 | GE JTP20 Electric Single Oven
Take GE Profile Oven LOC from pannel
the control board is bad,replace it there is no sequence to rectify this problem the board is bad
Jun 17, 2012 | GE Ovens
Oven displays "Supply Open Neutral" What does
I got this problem on my GE Trivection oven after a 2 minute blackout. "Supply Open Neutral" showed up and no other buttons worked. I shut off the breaker to the oven from outside and it still didn't work. I then turned the breaker off of the other appliances in the kitchen and turned the Trivection oven breaker on first and then it worked. I don't know if it was the order or whether I just turned it off for a longer period of time, but the oven started working normal again.
Nov 29, 2010 | GE Monogram® ZET3038 Dual Single Oven
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
F1 error/touch panel not working on GE Monogram Dual Oven
Usually, the F1 means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
I recommend a service call for this repair.
Jun 02, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
TOp Oven Light ..
if its a brand new unit (still in waranty) make the service call
Aug 30, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Re.probe and bake
I had the same problem and pulled off the contorl panel and removed the ribbion looking thing. You might have to do this a few times and wiggle it a little. It took me about 4 trys to get it to stop. also you can lock the control panel and the beeping will stop...this was my temp fix until I figured out how to get the control panel off and what to do.
Oct 11, 2007 | GE Profile JTP56 Electric Double Oven
Ovens Logo
47 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
