Question about TDK Tremor S150 Computer Speakers
When I listened to music, the subwoofer has тщшыув also music has stopped
What can cause a sub woofer and room speaker woofer to stop
Check wiring for loose connection...may have to open speaker enclosure.
Jan 04, 2016 | Velodyne CHT-8 Subwoofer
I have 2 pairs of Bose 901 (4) which amp or receiver do I need just to listen music.
That all depends on how much money you want to spend!
My best advice would be to go to a proper hi-fi shop that has the time and the expertise to advice you. If you are in England I would recommend you go to somewhere like Richer Sounds, link below.
Places like this will even let you test the amp with your speakers.
http://www.froogle.richersounds.com/
Nov 13, 2015 | Bose Audio Players & Recorders
I'm having a problem when i listen to music threw Bluetooth on my car stereo, when i play music using Bluetooth from my phone my subwoofers don't turn on, but when i listen to the radio my subwoofers work
Generally, subwoofers require separate circuitry. Your car radio has that circuitry. Bluetooth is set up for stereo only and your phone will only supply stereo output
Nov 07, 2014 | Cell Phones
My friend just installed my subwoofers into my car. They are Dual 12 inch 1100 Watt speakers with a Pyle 1400 watt 2 channel amp. He installed his own speakers in his car so i trusted him with mine. He...
your getting fead back. check the ground on the amp it needs to be bare metal and tight also check the rcas they need to be tight and if its only hapening wile u play the ipod try switching wires from the i pod it hapens all the time with aux cables they break easy.
Sep 28, 2010 | Dual Car Audio & Video
What is the best way to install a subwoofer
it depends on if you are using a suspension subwoofer or a ported subwoofer setup.
Mar 13, 2010 | Car Audio & Video
Bass goes off when i turn up the volume
You need to install a heavier gauge wire to your amp and a capacitor. It works fine at low volumes because there is enough wattage from the battery to power the bass output of the amp but at higher volumes the amp does not have enough power.
Heavier gauge wire supplies more poer, and a capacitor stores a reserve of wattage for the amp to use so that it does not run out while blasting your tunes.
Jun 02, 2009 | Fusion FEW12PK Car Subwoofer
How big of am amp do i need?
Depending on what kind of music you listen to I would say around a 1200 Watt Amp would suffice for what you are saying. Thank you for using Fix Ya! Don't forget to rate the overall answer to your question.
Jan 28, 2009 | Power Acoustik 12 1200w Subwoofer Car...
Music stops 30 seconds into the song
does the music stop? or do the sub(s) kick out. your amp might be to big for the sub rating , try turning down the gain
Jan 19, 2009 | Sony Xplode P5 Turbo Subwoofers Car...
Type r subs
your amp mine be going in to protection mode
Sep 07, 2008 | Alpine Type-R SWR-1242D Car Subwoofer
Subwoofers and amps
If you replace the head unit, that will make a big difference. If not, then it really depends on the type of music you primarily listen to. From a single sub setup, an 8 or 10 in a sealed box is best for punchy base, i.e. alternative, hard rock... A 12, 15, or 18 is designed to reach those lower bass frequencies and are suited better for ported enclosures. I.e. Rap, bass heavy Regge, etc...However, that's not to say that you can't go back and forth between them. The main difference is that a 10 and below tends to be more accurate, and can follow the kick drums, for example, a lot faster than larger woofers. Determine what your primary listening music is, what you want out of your system, and a maximum price for everything first. Then, I can suggest woofers, amps, etc.
Jun 24, 2008 | Car Audio & Video
TDK Tremor S150 Computer Speakers Logo
20 people viewed this question
Top TDK Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
Ben Armstrong
Are you a TDK Audio Player and Recorder Expert? Answer questions, earn points and help others
