Question about E-Machines Computers & Internet
Power button connection location on motherboard
  • 2,229 Answers
Looking at the motherboard from the top with the card slots on the left, you will see a double row of pins somewhere in the lower right corner. Two of those pins will be marked either PWR or PWR SW (for power switch). Those are the pins you want.
If you can't see the writing clearly, you can always short the pins, two by two with a small screwdriver until you find the two that start the computer.
Posted on Sep 07, 2010
I have disconnected all th ewire from my motherboard and i have installed all wire but unable to connect pw button,reset button,HDD led wire and anothed LED wire please tell me how can i install them in...
Locate the case connector pins on your motherboard. This will be a bank of two rows with 10-12 pins in each row. Each pin will be about 1 cm in length.2 Locate the power lead behind the power button on your computer case. The lead will consist of two thin wires, usually white and black, held together by a small plastic cap.3 Examine the underside of the power lead for an arrow or dot. If one is present, the marking signifies the first pin. This must correspond with the first pin on the motherboard, which will also be indicated by an arrow, dot, or number. If no markings are present, the lead can be installed in either orientation.4 Place the lead over the power pins within the pin bank. The correct pins will be indicated by a diagram on the motherboard, or by a picture in your motherboard's instruction manual.5 Connect the power cable to the back of your computer, and turn the computer on.
  • Oct 14, 2011 | ASUS P5PE-VM Motherboard
    I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
    The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
    Shut down the Acer Aspire L100 and turn the tower around.
    Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
    Unplug the power cord from the rear of the tower
    Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
    Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
    Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    HAVE FIC AM 37 MOBO AND THE SW POWER ON IS DISCONNECTED, NEED TO KONW WHERE TO HOOKED THIS BACK ON
    It needs to be connected to the F_PNL connector, located near the battery.
    It has the following pin assignment:
    L+ L- P P x
    H+ H- R R N
    L ... Power LED
    P ... Power button
    x ... missing pin
    H ... HDD LED
    R ... Reset button
    N ... not connected
    Mar 17, 2010 | FIC AM 37 Motherboard
    I can't find where to connect the power switch on a fic k8m-800m
    N R R H H
    x P P L L
    N ... not connected
    R ... Reset button
    H ... HDD LED
    x ... missing pin
    P ... Power button
    L ... Power LED
    Mar 16, 2010 | Computers & Internet
    Need to know where to connect the reset switch pin.
    It may be just a pinhole. Convention puts it right by the power button.
    If you can't find it, you can hold the power button down for 3-4 seconds until it shuts off, or simply unplug it and plug it back in. It will have the same effect.
    Jan 03, 2010 | E-Machines EMA IMPERIAL GV (845GV) TG3...
    Found power switch
    Do you mean the pin set on the motherboard to connect your power on button's wires to?
    This connector labeled: FPBUT_IN In Power switch connects to pin 6 and 8
    Find Pin 1 and count down and then next row count down. Sounds like this connects to the second row and there should be no pin for pin location 7
    This is the link to download the board PDF manual, go to page 78.
    Your Motherboard has a different number assigned by Intell but is the same as yours.
    Regards,
    Worldvet
    May 24, 2008 | Intel Motherboard
    Power for HP554e
    I will try to help you. Locate a 10-pin connector below your backup battery. This connector has only 9 pins. It has four pins on the top and 5 pins on the bottom. Connect connector from your power button to the top row pins 6 and 8. Look at the diagram below I marked connection points with the “+” sign.
    2 4 6 8
    0 0 + +
    0 0 0 0 0
    1 3 5 7 9
    Just for your references. Pins 2-4 for Power LED, 1-3 for Hard Drive LED, 5-7 for Reset Button.
    Regards
    May 23, 2008 | Cornerstone FIC AM37-L Socket A XP...
    Power button wiring help
    Hello Chub, Your motherboard manual can be downloaded at this link: http://support.asus.com/download/download.aspx?SLanguage=en-us If you go to page 2-31 in the above manual the diagram should show you exactly where your front panel power switch connects to your motherboard. You want to connect it to the position marked below as ?ATX Power Switch?. Let us know if you have any other questions and please don?t forget to rate the posting.
    Jan 15, 2007 | ASUS A8V Deluxe Motherboard
    Computers & Internet Logo
    67 people viewed this question
    Top E-Machines Computers & Internet Experts
    Matthew Spark
    Matthew Spark
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
