2005 Chrysler Town & Country Logo
Posted on Apr 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2005 town and country Sometimes will not start and stay running..after a few times trying it will go totally dead, after a few min it's fine? While all this is happening either all the driver dash lights are totally out or they will not turn off, When they will not turn off (even if shut off with key removed) have no fuel gage spedometer nothing.. Also while messing up there's a clicking sound that comes from the radio A/C heater area, you hear this noise is the times that the lights do not shut off..Power locks have also gone out durning all this and no longer work at all
Bill George
Level 3:
  • Chrysler Master 2,517 Answers
  • Posted on Apr 23, 2017
Bill George
Chrysler Master
Level 3:
Answers
2517
Questions
Helped
544757
Points
7493
May be a bad ignition switch or a bad ecm( computer).
4 Related Answers
Anonymous
  • 183 Answers
  • Posted on Apr 25, 2009
SOURCE: 2005 Chrysler town & country touring won't turn over.
Sounds like you need a starter, or you have a loose wire somewhere under the hood.
Anonymous
  • 47 Answers
  • Posted on Feb 22, 2010
SOURCE: why does my 2005 Town & Country radiator fan
The fan is computer controlled and will not come on untill it reaches 212Deg . It should come on though if you turn on the air conditioning, if not you could have a bad fan relay or relay plug.
Anonymous
  • 4 Answers
  • Posted on Mar 19, 2010
SOURCE: my 2005 chrysler town and country wont start.
it mite sound weird but your alternator mite be the prob like the diode on it can be out and it will make your car not start that is why your gauge jump like that so next time your gauge's jump as you try to start it but it just clicks it mite be the alt. hope this will help people out there.
Anonymous
  • 1033 Answers
  • Posted on Jul 16, 2010
SOURCE: 2003 Chrysler Town and Country will not turn over.
When you turn the switch over, does the lights dim or flicker? If that's the case then the battery don't have the power it needs to turn the engine over, so it could be the cables and post need cleaning, or the solenoid for the starter is bad. The description you give with the clicking sound, gives me the thought of starter solenoid, but always do the easiest and cheapest. "clean those terminals and post first"
2005 Dodge Town & Country will start but will not stay running when it's cold. After car warms up or in high temperatures it runs perfect
Clean the Throttle Body and MAF with Cleaner. That causes rough idle.
Also drop a bottle of Fuel System Restorer into half a tank of gas.
More ideas here, but start with the above.
https://www.google.com/search?q=2005+chrysler+town+and+country+rough+idle
How to fix a 2005 chrysler town and country that does not run?
Do you have any codes?tune up,fuel filter,crankshaft sensor.Sometimes new battery is not good it happen to me.
4answers
2005 town country Chrysler when I start it up it will go for just a few mintues then it will just stop like the gears just stop working and it wont move turn it off start back up it go for just a few min...
may be a pulley is stuck. if the serpentine belt is not circulating it will freeze the whole system. my jeep did the same thing . turned out one pulley was frozen and another loose. belt would turn few times then freeze
1helpful
2005 Town & Country Van dead battery after short trips
Possible dead cell in battery, most likely a fault in the charging system. First, Jump Vehicle to get started then remove the Negative cable. If the vehicle dies when you take the jumper cables away or when you disconnect the negative cable your alternator or charging system is faulty. If the vehicle runs without battery connected you have a bad cell in your battery, replace the battery.
1996 town and country van not starting
i had same problem and it was the computer my mechanic orderd on line out of Michigan only 96 computer for town and country will fit it total cost was258.00
Gauges go nuts when car is started
battery should be checked, low amperage will cause this problem. Replace battery and problem should correct. If any gauge spins around and stays on wrong side of stop, hold trip odometer knob in until diagnostics start. Dash will go thru a series of test and everything will be normal if test pass.
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
